Hi all!
I'm working on an nrf51822 (technically right now I'm using the PTR5518 as I'm still prototpying), and trying to set up a voltage divider on my pcb in order to measure an unknown resistance. Basically, I take the voltage measurement across the "lower" resistor (connected to the negative power supply terminal) through the NRF's ADC, and then convert that into an R2 using the known resistance value.
For this to work, that input/ADC pin has to draw minimal current, as a current moving through R1 means a voltage drop means changing my measurement across R2.
The problem is, right now I'm getting a pretty substantial (1.5-2V) voltage drop across that resistor, which must mean that my ADC pin is drawing some current. I've set the pin up as a standard AnalogIn = analog_value(pin#) using mbed, and I'm reading using V_meas = analog_value.read(). Am I going about this wrong? Is there some way that I can set the input impedance higher on my nrf? Or is the resistor I'm using (4.7M) too high? I didn't have this problem when I used a 10k resistor. Any help would be appreciated!
tldr: the ADC on my NRF51822 is drawing current and screwing with my measurement. How do I get it to stop?
