NRF51822 SPI slave semaphore tasks acquire and release
I wish to communicate with the chip via SPI NRF51822.
The NRF chip is configured as a slave. Based on the SPi_slave_example code, I can't set to 1 the semaphore task release and task ACQUIRE .
Those tasks are always equal to 0
Is there a particular way to get there?
best regardsimage description
  • Hi User2, sorry for late response, do you still have this problem?
  • Yes I still have the probleme, could we use function as assertparam?
  • Sorry, I misread your question.
    When you write 1 to any TASK in the nordic chip, it will still read as 0. If you want to see if it has worked or not, you have to look at the events. For example if you write SPI->TASKS_ACQUIRE = 1; Then to see if it worked you have to check if EVENTS_ACQUIRED == 1. If it is set to 1 then do your logic and clear the event by doing EVENTS_ACQUIRED = 0.
