error in ble_app_beacon sample when modyfing advertising parameters
Hi all, i have loaded the example on my smart beacon kit (nrf51822 chip with softdevice s110), and it runs without problems. But in this example, the "normal mode" of the beacon doesn't allow a device to connect, because the parameter in the advertising structure is like:
m_adv_params.type = BLE_GAP_ADV_TYPE_ADV_NONCONN_IND;
If i want to connect a device, i change NONCONN to DIRECT as stated in the libraries, but when i load it on the beacon i can't even see it advertising, just with this change. How can i fix this? Thanks in advance.
EDIT: add full code
/* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
 * The information contained herein is property of Nordic Semiconductor ASA.
 * Terms and conditions of usage are described in detail in NORDIC
 * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
 * Licensees are granted free, non-transferable use of the information. NO
 * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
 * the file.
/** @file
 * @defgroup ble_app_beacon_main main.c
 * @ingroup ble_app_beacon
 * @brief Beacon Transmitter Sample Application main file.
 * This file contains the source code for a beacon transmitter sample application.
#include <stdbool.h>
#include <stdint.h>
#include "ble_conn_params.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "nordic_common.h"
#include "softdevice_handler.h"
#include "pstorage.h"
#include "app_gpiote.h"
#include "app_timer.h"
#include "app_button.h"
#include "pca20006.h"
#include "ble_bcs.h"
#include "ble_dfu.h"
#include "dfu_app_handler_mod.h"
#include "led_softblink.h"
#include "beacon.h"
/* Button definitions */
#define BOOTLOADER_BUTTON_PIN           BUTTON_0                                    /**< Button used to enter DFU mode. */
#define CONFIG_MODE_BUTTON_PIN          BUTTON_1                                    /**< Button used to enter config mode. */
#define APP_GPIOTE_MAX_USERS            2                                           /**< Max users of app_gpiote */
#define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50, APP_TIMER_PRESCALER)    /**< Button detection delay in ticks */
/* LED definitions */
#define LED_R_MSK                       (1UL << LED_RGB_RED)                            /**< Red LED bitmask */
#define LED_G_MSK                       (1UL << LED_RGB_GREEN)                          /**< Green LED bitmask */
#define LED_B_MSK                       (1UL << LED_RGB_BLUE)                           /**< Blue LED bitmask */
#define APP_CONFIG_MODE_LED_MSK         (LED_R_MSK | LED_G_MSK)                     /**< Blinking yellow when device is in config mode */
#define APP_BEACON_MODE_LED_MSK         (LED_R_MSK | LED_B_MSK)                     /**< Blinking purple when device is advertising as beacon */
#define ASSERT_LED_PIN_NO               LED_RGB_RED                                     /**< Red LED to indicate assert */
/* Beacon configuration mode parameters */
#define BEACON_CONFIG_NAME              "BeaconConfig"                              /**< Name of device. Will be included in the advertising data. */
#define APP_CONFIG_ADV_INTERVAL         MSEC_TO_UNITS(100, UNIT_0_625_MS)           /**< The advertising interval in configuration mode (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_CONFIG_ADV_TIMEOUT          30                                          /**< The advertising timeout (in units of seconds). */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(500, UNIT_1_25_MS)            /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(1000, UNIT_1_25_MS)           /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time between each call to sd_ble_gap_conn_param_update after the first (5 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_TIMEOUT               30                                          /**< Timeout for Pairing Request or Security Request (in seconds). */
#define SEC_PARAM_BOND                  0                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
/* App timer parameters */
#define APP_TIMER_PRESCALER             0                                           /**< RTC prescaler value used by app_timer */
#define APP_TIMER_MAX_TIMERS            3                                           /**< One for each module + one for ble_conn_params + a few extra */
#define APP_TIMER_OP_QUEUE_SIZE         3                                           /**< Maximum number of timeout handlers pending execution */
/* App scheduler parameters */
#define SCHED_MAX_EVENT_DATA_SIZE       sizeof(app_timer_event_t)                   /**< Maximum size of scheduler events. Note that scheduler BLE stack events do not contain any data, as the events are being pulled from the stack in the event handler. */
#define SCHED_QUEUE_SIZE                10                                          /**< Maximum number of events in the scheduler queue. */
/* DFU definitions */
#define DFU_REV_MAJOR                   0x00                                        /** DFU Major revision number to be exposed. */
#define DFU_REV_MINOR                   0x01                                        /** DFU Minor revision number to be exposed. */
#define DFU_REVISION                    ((DFU_REV_MAJOR << 8) | DFU_REV_MINOR)      /** DFU Revision number to be exposed. Combined of major and minor versions. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define IS_SRVC_CHANGED_CHARACT_PRESENT  1                                          /**< Include or not the service_changed characteristic. if not enabled, the server's database cannot be changed for the lifetime of the device*/
/* Static variables */
static beacon_mode_t        m_beacon_mode;                                          /**< Current beacon mode */
static beacon_flash_db_t    *p_beacon;                                              /**< Pointer to beacon params */
static pstorage_handle_t    m_pstorage_block_id;                                    /**< Pstorage handle for beacon params */
static ble_gap_sec_params_t m_sec_params;                                           /**< Security requirements for this application. */
static uint16_t             m_conn_handle = BLE_CONN_HANDLE_INVALID;                /**< Handle of the current connection. */
static ble_bcs_t            m_bcs;                                                  /**< Beacon Configuration Service structure.*/
static ble_dfu_t            m_dfus;                                                 /**< Structure used to identify the DFU service. */
static ble_gap_adv_params_t m_adv_params;                                           /**< Parameters to be passed to the stack when starting advertising. */
static bool                 m_beacon_reset = false;                                 /**< Flag to reset system after flash access has finished. */
static bool                 m_beacon_start = false;                                 /**< Flag to setup and start beacon after flash access has finished. */
/* Prototypes */
static void beacon_reset(void);
static void beacon_start(beacon_mode_t mode);
/**@brief Function for error handling, which is called when an error has occurred.
 *          how your product is supposed to react in case of error.
 * @param[in] error_code  Error code supplied to the handler.
 * @param[in] line_num    Line number where the handler is called.
 * @param[in] p_file_name Pointer to the file name.
void app_error_handler(uint32_t error_code, uint32_t line_num, const uint8_t * p_file_name)
    uint32_t err_code = error_code;
    uint32_t lin_num  = line_num;
    const uint8_t * p_fname = p_file_name;
    nrf_gpio_pin_clear(ASSERT_LED_PIN_NO);
    UNUSED_VARIABLE(err_code);
    UNUSED_VARIABLE(lin_num);
    UNUSED_VARIABLE(p_fname);
    // On assert, the system can only recover on reset.
    NVIC_SystemReset();
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
/**@brief Function for handeling storage access complete events.
 * @details This function is called through the sheduler from sys_evt_dispatch when storage access is complete
 * @param[in]   data   Event data, not used.
 * @param[in]   size   Event data size, not used.
static void storage_access_complete_handler(void *data, uint16_t size)
    if (m_beacon_reset)
        beacon_reset();
    else if (m_beacon_start)
        beacon_start(m_beacon_mode);
/**@brief Function for dispatching a system event to interested modules.
 * @details This function is called from the System event interrupt handler after a system
 *          event has been received.
 * @param[in]   sys_evt   System stack event.
static void sys_evt_dispatch(uint32_t sys_evt)
    uint32_t err_code;
    uint32_t count;
    pstorage_sys_event_handler(sys_evt);
    // Check if storage access is in progress.
    err_code = pstorage_access_status_get(&count);
    if ((err_code == NRF_SUCCESS) && (count == 0))
        err_code = app_sched_event_put(0, 0, storage_access_complete_handler);
/**@brief Function for the LEDs initialization.
 * @details Initializes all LEDs used by this application and starts softblink timer.
static void leds_init(void)
    uint32_t err_code;
    led_sb_init_params_t led_sb_init_params;
    nrf_gpio_cfg_output(LED_RGB_RED);
    nrf_gpio_cfg_output(LED_RGB_GREEN);
    nrf_gpio_cfg_output(LED_RGB_BLUE);
    nrf_gpio_pin_set(LED_RGB_RED);
    nrf_gpio_pin_set(LED_RGB_GREEN);
    nrf_gpio_pin_set(LED_RGB_BLUE);
    led_sb_init_params.active_high     = false;
    led_sb_init_params.duty_cycle_max  = 20;
    led_sb_init_params.duty_cycle_min  = 0;
    led_sb_init_params.duty_cycle_step = 1;
    led_sb_init_params.leds_pin_bm     = (LED_R_MSK | LED_G_MSK | LED_B_MSK);
    led_sb_init_params.off_time_ms     = 4000;
    led_sb_init_params.on_time_ms      = 0;
    err_code = led_softblink_init(&led_sb_init_params);
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
static void advertising_init(beacon_mode_t mode)
    if (mode == beacon_mode_normal)
        uint32_t        err_code;
        ble_advdata_t   advdata;
        uint8_t         flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
        ble_advdata_manuf_data_t manuf_specific_data;
        manuf_specific_data.company_identifier = p_beacon->data.company_id;
        manuf_specific_data.data.p_data        = p_beacon->data.beacon_data;
        manuf_specific_data.data.size          = APP_BEACON_MANUF_DATA_LEN;
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        advdata.flags.size              = sizeof(flags);
        advdata.flags.p_data            = &flags;
        advdata.p_manuf_specific_data   = &manuf_specific_data;
        err_code = ble_advdata_set(&advdata, NULL);
        // Initialize advertising parameters (used when starting advertising).
        memset(&m_adv_params, 0, sizeof(m_adv_params));
        m_adv_params.p_peer_addr = NULL;                             // Undirected advertisement.
        m_adv_params.fp          = BLE_GAP_ADV_FP_ANY;
        m_adv_params.interval    = MSEC_TO_UNITS(p_beacon->data.adv_interval, UNIT_0_625_MS);
        m_adv_params.timeout     = APP_BEACON_ADV_TIMEOUT;
    else if (mode == beacon_mode_config)
        uint32_t      err_code;
        ble_advdata_t scanrsp;
        uint8_t       flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        ble_uuid_t adv_uuids[] = {{BCS_UUID_SERVICE, m_bcs.uuid_type}};
        advdata.include_appearance      = true;
        memset(&scanrsp, 0, sizeof(scanrsp));
        scanrsp.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        scanrsp.uuids_complete.p_uuids  = adv_uuids;
        err_code = ble_advdata_set(&advdata, &scanrsp);
        m_adv_params.type        = BLE_GAP_ADV_TYPE_ADV_IND;
        m_adv_params.interval    = APP_CONFIG_ADV_INTERVAL;
        m_adv_params.timeout     = APP_CONFIG_ADV_TIMEOUT;
        APP_ERROR_CHECK_BOOL(false);
    uint32_t err_code;
    err_code = sd_ble_gap_adv_start(&m_adv_params);
/**@brief Function for the Power manager.
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
/**@brief Function for handeling button presses.
static void button_handler(uint8_t pin_no, uint8_t action)
    if (action == APP_BUTTON_PUSH)
        if(pin_no == CONFIG_MODE_BUTTON_PIN)
            beacon_reset();
        else if (pin_no == BOOTLOADER_BUTTON_PIN)
            beacon_reset();
/**@brief Function for initializing and enabling the app_button module.
static void buttons_init(void)
    uint32_t err_code;
    // @note: Array must be static because a pointer to it will be saved in the Button handler
    // module.
    static app_button_cfg_t buttons[] =
        {CONFIG_MODE_BUTTON_PIN, APP_BUTTON_ACTIVE_LOW, BUTTON_PULL, button_handler},
        {BOOTLOADER_BUTTON_PIN, APP_BUTTON_ACTIVE_LOW, BUTTON_PULL, button_handler}
    APP_BUTTON_INIT(buttons, sizeof(buttons) / sizeof(buttons[0]), BUTTON_DETECTION_DELAY, true);
    err_code = app_button_enable();
/**@brief Function for handling the writes to the configuration characteristics of the beacon configuration service.
 * @detail A pointer to this function is passed to the service in its init structure.
static void beacon_write_handler(ble_bcs_t * p_lbs, beacon_data_type_t type, uint8_t *data)
    uint32_t err_code;
    static beacon_flash_db_t tmp;
    memcpy(&tmp, p_beacon, sizeof(beacon_flash_db_t));
    tmp.data.magic_byte = MAGIC_FLASH_BYTE;
    switch(type)
        case beacon_maj_min_data:
            tmp.data.beacon_data[BEACON_MANUF_DAT_MAJOR_H_IDX] = data[0];
            tmp.data.beacon_data[BEACON_MANUF_DAT_MAJOR_L_IDX] = data[1];
            tmp.data.beacon_data[BEACON_MANUF_DAT_MINOR_H_IDX] = data[2];
            tmp.data.beacon_data[BEACON_MANUF_DAT_MINOR_L_IDX] = data[3];
        case beacon_measured_rssi_data:
            tmp.data.beacon_data[BEACON_MANUF_DAT_RSSI_IDX] = data[0];
        case beacon_uuid_data:
            memcpy(&tmp.data.beacon_data[BEACON_MANUF_DAT_UUID_IDX], data, BCS_DATA_ID_LEN);
        case beacon_company_id_data:
            tmp.data.company_id = (data[1] << 8) + data[0];
        case beacon_adv_interval_data:
            tmp.data.adv_interval = (data[1] << 8) + data[0];
            if (tmp.data.adv_interval < APP_BEACON_ADV_INTERVAL_MIN_MS)
                tmp.data.adv_interval = APP_BEACON_ADV_INTERVAL_MIN_MS;
            else if (tmp.data.adv_interval > APP_BEACON_ADV_INTERVAL_MAX_MS)
                tmp.data.adv_interval = APP_BEACON_ADV_INTERVAL_MAX_MS;
        case beacon_led_data:
            tmp.data.led_state = data[0];
    err_code = pstorage_clear(&m_pstorage_block_id, sizeof(beacon_flash_db_t));
    err_code = pstorage_store(&m_pstorage_block_id, (uint8_t *)&tmp, sizeof(beacon_flash_db_t), 0);
 * @details This function shall be used to setup all the necessary GAP (Generic Access Profile)
 *          parameters of the device. It also sets the permissions and appearance.
    uint32_t                err_code;
    err_code = sd_ble_gap_device_name_set(&sec_mode, BEACON_CONFIG_NAME, strlen(BEACON_CONFIG_NAME));
/**@brief Function for stopping advertising.
static void advertising_stop(void)
    uint32_t err_code;
    err_code = sd_ble_gap_adv_stop();
    err_code = led_softblink_stop(APP_CONFIG_MODE_LED_MSK);
/**@brief Function for preparing before reset.
static void dfu_reset_prepare(void)
    uint32_t err_code;
    if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
        // Disconnect from peer.
        err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        // If not connected, then the device will be advertising. Hence stop the advertising.
        advertising_stop();
    err_code = ble_conn_params_stop();
    uint32_t err_code;
    ble_bcs_init_t init;
    ble_dfu_init_t   dfus_init;
    // Initialize the Device Firmware Update Service.
    memset(&dfus_init, 0, sizeof(dfus_init));
    dfus_init.evt_handler    = dfu_app_on_dfu_evt;
    dfus_init.error_handler  = NULL; //service_error_handler - Not used as only the switch from app to DFU mode is required and not full dfu service.
    dfus_init.revision       = DFU_REVISION;
    err_code = ble_dfu_init(&m_dfus, &dfus_init);
    dfu_app_reset_prepare_set(dfu_reset_prepare);
    init.beacon_write_handler = beacon_write_handler;
    init.p_beacon = p_beacon;
    err_code = ble_bcs_init(&m_bcs, &init);
/**@brief Function for initializing security parameters.
static void sec_params_init(void)
    m_sec_params.timeout      = SEC_PARAM_TIMEOUT;
    m_sec_params.bond         = SEC_PARAM_BOND;
    m_sec_params.mitm         = SEC_PARAM_MITM;
    m_sec_params.io_caps      = SEC_PARAM_IO_CAPABILITIES;
    m_sec_params.oob          = SEC_PARAM_OOB;
    m_sec_params.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
    m_sec_params.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
 * @param[in]   p_evt   Event received from the Connection Parameters Module.
    uint32_t err_code;
    if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED)
/**@brief Function for handling a Connection Parameters error.
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the Application's BLE Stack events.
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t                         err_code = NRF_SUCCESS;
    static ble_gap_evt_auth_status_t m_auth_status;
    ble_gap_enc_info_t *             p_enc_info;
        case BLE_GAP_EVT_CONNECTED:
            beacon_reset();
            err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                   BLE_GAP_SEC_STATUS_SUCCESS,
                                                   &m_sec_params);
            err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0);
        case BLE_GAP_EVT_AUTH_STATUS:
            m_auth_status = p_ble_evt->evt.gap_evt.params.auth_status;
        case BLE_GAP_EVT_SEC_INFO_REQUEST:
            p_enc_info = &m_auth_status.periph_keys.enc_info;
            if (p_enc_info->div == p_ble_evt->evt.gap_evt.params.sec_info_request.div)
                err_code = sd_ble_gap_sec_info_reply(m_conn_handle, p_enc_info, NULL);
                // No keys found for this device
                err_code = sd_ble_gap_sec_info_reply(m_conn_handle, NULL, NULL);
        case BLE_GAP_EVT_TIMEOUT:
            if (p_ble_evt->evt.gap_evt.params.timeout.src == BLE_GAP_TIMEOUT_SRC_ADVERTISEMENT)
                beacon_reset();
/**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
 * @details This function is called from the scheduler in the main loop after a BLE stack
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    ble_conn_params_on_ble_evt(p_ble_evt);
    ble_bcs_on_ble_evt(&m_bcs, p_ble_evt);
    ble_dfu_on_ble_evt(&m_dfus, p_ble_evt);
    uint32_t err_code;
    // Initialize the SoftDevice handler module.
    SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_50_PPM, true);
    // Enable BLE stack
    ble_enable_params_t ble_enable_params;
    memset(&ble_enable_params, 0, sizeof(ble_enable_params));
    ble_enable_params.gatts_enable_params.service_changed = IS_SRVC_CHANGED_CHARACT_PRESENT;
    err_code = sd_ble_enable(&ble_enable_params);
    // Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
/** @brief Function for handling pstorage events
static void pstorage_ntf_cb(pstorage_handle_t *  p_handle,
                            uint8_t              op_code,
                            uint32_t             result,
                            uint8_t *            p_data,
                            uint32_t             data_len)
    APP_ERROR_CHECK(result);
/** @brief Function for initializing pstorage
static void flash_access_init(void)
    uint32_t err_code;
    err_code = pstorage_init();
/** @brief Function to get a pointer to beacon parameters in flash. Should only be called once during initialization.
static beacon_flash_db_t * beacon_params_get(void)
    uint32_t err_code;
    pstorage_module_param_t pstorage_param;
    pstorage_param.cb = pstorage_ntf_cb;
    pstorage_param.block_size = sizeof(beacon_flash_db_t);
    pstorage_param.block_count = 1;
    err_code = pstorage_register(&pstorage_param, &m_pstorage_block_id);
    return (beacon_flash_db_t *)m_pstorage_block_id.block_id;
/** @brief Function for writing default beacon parameters to flash.
static void beacon_params_default_set(void)
    uint32_t err_code;
    uint8_t beacon_data[APP_BEACON_MANUF_DATA_LEN] =  /**< Information advertised by the beacon. */
        APP_DEVICE_TYPE,           // Manufacturer specific information. Specifies the device type in this
                                   // implementation.
        APP_ADV_DATA_LENGTH,       // Manufacturer specific information. Specifies the length of the
                                   // manufacturer specific data in this implementation.
        APP_DEFAULT_BEACON_UUID,   // 128 bit UUID value.
        APP_DEFAULT_MAJOR_VALUE,   // Major arbitrary value that can be used to distinguish between beacons.
        APP_DEFAULT_MINOR_VALUE,   // Minor arbitrary value that can be used to distinguish between beacons.
        APP_DEFAULT_MEASURED_RSSI  // Manufacturer specific information. The beacon's measured TX power in
                                   // this implementation.
    tmp.data.adv_interval = APP_BEACON_DEFAULT_ADV_INTERVAL_MS;
    tmp.data.company_id   = APP_DEFAULT_COMPANY_IDENTIFIER;
    tmp.data.led_state    = 0x01;
    beacon_data[BEACON_MANUF_DAT_MINOR_L_IDX] = (uint8_t)(NRF_FICR->DEVICEADDR[0] & 0xFFUL);
    beacon_data[BEACON_MANUF_DAT_MINOR_H_IDX] = (uint8_t)((NRF_FICR->DEVICEADDR[0] >>  8) & 0xFFUL);
    beacon_data[BEACON_MANUF_DAT_MAJOR_L_IDX] = (uint8_t)((NRF_FICR->DEVICEADDR[0] >> 16) & 0xFFUL);
    beacon_data[BEACON_MANUF_DAT_MAJOR_H_IDX] = (uint8_t)((NRF_FICR->DEVICEADDR[0] >> 24) & 0xFFUL);
    memcpy(tmp.data.beacon_data, beacon_data, APP_BEACON_MANUF_DATA_LEN);
/** @brief Function for setup of beacon operation.
static void beacon_setup(beacon_mode_t mode)
    if(mode == beacon_mode_config)
        gap_params_init();
        services_init();
        advertising_init(mode);
        conn_params_init();
        sec_params_init();
        led_softblink_off_time_set(2000);
        led_softblink_start(APP_CONFIG_MODE_LED_MSK);
        if (p_beacon->data.led_state)
            led_softblink_start(APP_BEACON_MODE_LED_MSK);
/** @brief Function for reseting the beacon.
    uint32_t err_code;
    uint32_t count;
    if (count == 0)
        NVIC_SystemReset();
        m_beacon_reset = true;
/** @brief Function for starting beacon operation.
    uint32_t err_code;
    uint32_t count;
    if (count == 0)
        // Setup beacon mode
        beacon_setup(m_beacon_mode);
        // Start advertising
        advertising_start();
        m_beacon_start = true;
/** @brief Function for reading the beacon mode button.
static beacon_mode_t beacon_mode_button_read(void)
    uint32_t err_code;
    bool config_mode;
    err_code = app_button_is_pushed(0, &config_mode);
    return config_mode ? beacon_mode_config : beacon_mode_normal;
 * @brief Function for application main entry.
    // Initialize.
    APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, false);
    APP_GPIOTE_INIT(APP_GPIOTE_MAX_USERS);
    buttons_init();
    leds_init();
    ble_stack_init();
    flash_access_init();
    // Read beacon mode
    m_beacon_mode = beacon_mode_button_read();
    // Read beacon params from flash
    p_beacon = beacon_params_get();
    if (p_beacon->data.magic_byte != MAGIC_FLASH_BYTE)
        // No valid params found, write default params.
        beacon_params_default_set();
    // Enter main loop.
    for (;;)
        app_sched_execute();
        power_manage();
