I use GCC as IDE because I must(though I debug perfectly via Keil v5). I migrated to eclipse GCC by the tutorial published here on 'Devzone'. I added some C codes and drivers for NRF 51. 'spi_drv_master' works fine but not 'twi_drv_twi'.
I'm trying to use the TWI(I2C) service, but I cannot continue through the 'nrf_drv_twi_tx' function to end it through 'twi_transfer' because:
p_cb->transfer_in_progress = true
thus, I always return NRF_ERROR_BUSY and fail. here is the snippet from 'twi_transfer':
static ret_code_t twi_transfer(nrf_drv_twi_t const * const p_instance,
uint8_t address,
uint8_t const * p_data,
uint32_t length,
bool xfer_pending,
bool is_tx)
ASSERT(m_cb[p_instance->instance_id].state == NRF_DRV_STATE_POWERED_ON);
ASSERT(length > 0);
control_block_t * p_cb = &m_cb[p_instance->instance_id];
bool is_busy = false;
CRITICAL_REGION_ENTER();
if (p_cb->transfer_in_progress)
is_busy = true;
p_cb->transfer_in_progress = true;
CRITICAL_REGION_EXIT();
if (is_busy)
return NRF_ERROR_BUSY;
'ASSERT' function does not seem to work either since:
p_cb->state = NRF_DRV_STATE_UNINTIALIZED
and that occurs when I hit the control_block_t * p_cb = &m_cb[p_instance->instance_id];
breakpoint.
when I hit the bool is_busy = false breakpoint, only then when I get:
p_cb->state = NRF_DRV_STATE_POWERED_ON
as mentioned above, is_busy = true; and I return and fail.
here is how I initalized the TWI:
void twi_i2c_init (void)
ret_code_t err_code;
// nrf_gpio_cfg_input(MAX_GPIO_INT_PIN,NRF_GPIO_PIN_PULLUP);
const nrf_drv_twi_config_t twi_i2c_MAX30101_config = {
.scl = I2C_SCL_PIN,
.sda = I2C_SDA_PIN,
.frequency = NRF_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH
err_code = nrf_drv_twi_init(&twi_i2c_MAX30101, &twi_i2c_MAX30101_config, (nrf_drv_twi_evt_handler_t)twi_i2c_handler, NULL);
nrf_drv_twi_enable(&twi_i2c_MAX30101);
and here is how I read from TWI:
void twi_i2c_MAX30101_read(uint8_t reg_addr, uint8_t* rxBuff, int size)
m_tx_done = true;
twi_i2c_init();
if((0 < size) && (size < I2C_RXBUFFER_SIZE))
/* Writing to MAX30101 */
i2cTransfer[0] = reg_addr;
rxBuffer.size = size;
// if(MAX30101_FIFO_read_flag)
// while(nrf_gpio_pin_read(MAX_GPIO_INT_PIN) == 1);
// MAX30101_FIFO_read_flag = 0;
err_code = nrf_drv_twi_tx(&twi_i2c_MAX30101, MAX30101_ADDRESS>>1, i2cTransfer, 1, true);
do{
// Make sure any pending events are cleared
__SEV();
__WFE();
// Enter System ON sleep mode
__WFE();
}while(m_rx_done == false);
m_rx_done = false;
// i2cTransfer = {0};
for(int i=0; i < size; i++)
rxBuff[i] = rxBuffer.rx_Buffer[i];
// rxBuff_t rxBuffer = {0};
I tried earlier to impose:
m_cb[p_instance->instance_id].transfer_in_progress = false;
but that did not help me to transfer data. I transfer nonesence.
What should I do? Via Keil it works fine.
Idan
