OTA DFU Bootloader SDK6.1
We've got devices that are out in the field which were built on SDK6.1 w/ 110 SoftDevice 7.1.0 on an nRF51822.
Went with the dual-banked solution as that was what was available at the time of development, but we've run up against the allowed codespace w/ the dual-banked solution. I've been able to get the Single Bank solution working, and am able to use it w/ nRF Toolbox to load our Application image, but have not been able to successfully use nRF Toolbox to update our existing dual-bank bootloader.
I've been referencing the Master Control Panel Init Packet Handling -- and used the nrfutil.exe in the latest Master Control Panel (3.10..) to generate a package (ZIP) -- but when I attempt to DFU, I get the following error: "Init packet with 2-byte CRC supported. Extended init packet found."
My understanding is that the 2-byte CRC is what was supported in the early SDK6.1 that we used. I'm (ideally) wanting to use the nrfutil.exe application to generate the appropriate package that is compatible with the dual-bank bootloader that exists on our devices in the field.
Any pointers would be greatly appreciated.
Thanks! -Tim
