Startup & data initialisation problems with gcc4.9.3 under eclipse environnement
I'm working on nRF52822 device with gcc4.9.3 compiler under eclipse environnement (with gnuarm toolchain plugin).
I have some problems with data initialisation. To check what is wrong I made this simple example:
volatile uint32_t test_data=0x12345678;
volatile uint32_t test_bss = 0;
int main(void) {
	printf("test data %08X\n", (int)test_data);
	test_data = 0;
	printf("test bss %d\n", (int)test_bss);
	test_bss = 1;
On the first launch, the console shows:
test data 12345678
test bss 980
Then I generate a reset to restart my test, the console shows:
test data 00000000
test bss 1
So
a) the "test_data" value is well initialized on the first time, but not on the following ones.
b) the "test_bss" value is never initialized.
Note, my linker options are -T "D:\Eclipse\eclipse64-mars\workbench.arm\nRF52\nRF52_AA.ld" -Xlinker --gc-sections -Wl,-Map,"nRF52.map" --specs=rdimon.specs
I use rdimon library to have the SWO console.
If I try to debug the code, in the statup routine form "gcc_startup_nrf52.s" file, some values (addresses) are not correct.
Reset_Handler:
    ldr r1, =__etext					; <= value correspond to the end of text section
    ldr r2, =__data_start__				; <= value correspond to the start of the RAM (0x20000000)
    ldr r3, =__bss_start__				; !! value = 0x8000 doesn't correspond to the start of bss section !!
So the initialization of data is not done here. I guess that it's done inside crt0 routine.
Then to initialize the bss section I've compiled with -D__STARTUP_CLEAR_BSS to be sure the the following code will be added.
#ifdef __STARTUP_CLEAR_BSS
    ldr r1, =__bss_start__				; !! value still set to 0x8000
    ldr r2, =__bss_end__				; !! value = 0x8000 doesn't correspond to the end of bss section !!
    movs r0, 0
    subs r2, r1
    ble .L_loop3_done
.L_loop3:
    subs r2, #4
    str r0, [r1, r2]
    bgt .L_loop3
.L_loop3_done:
#endif /* __STARTUP_CLEAR_BSS */
My linker script is like this
MEMORY
  FLASH (rx) : ORIGIN = 0x00000000, LENGTH = 0x80000
  RAM (rwx) :  ORIGIN = 0x20000000, LENGTH = 0x10000
    .bss :
        . = ALIGN(4);
        __bss_start__ = .;
        *(.bss*)				# bss section content should be located between __bss_start__ and __bss_end__
        *(COMMON)
        . = ALIGN(4);
        __bss_end__ = .;
    } > RAM
  1. I don't know why bss_start and bss_end are not set to right values
  2. I don't know why crt routine doesn't initialize correctly the memory
Thanks for reply.
Regards, Thierry
    I've copied and updated for nRF52 MCU an old linker script from another project (STM32 MCU). With this linker script, bss and data sections are correct with and without --specs=rdimon.specs.
    The bad linker script I use is provided by nordic (nRF5_SDK_11.0.0_89a8197).
    It's composed by the files :
    the first is located in the example directory <sdk_location>\examples\peripheral\blinky\pca10040\blank\armgcc\blinky_gcc_nrf52.ld and the second is located in the directory <sdk_location>\components\toolchain\nrf5x_common.ld
    I've just made single file including this two files
    I don't know why it's doesn't work !!!
    Below is my linker script:
    ** thln linker script updated 21/04/2016 form STM32 project
    /* GROUP(-lgcc -lc -lnosys) */
    GROUP(-lgcc -lc -lrdimon)
    /* Entry Point */
    ENTRY(Reset_Handler)
    /* Specify the memory areas */
    MEMORY
      FLASH (rx)      : ORIGIN = 0x00000000, LENGTH = 512K
      RAM (xrw)       : ORIGIN = 0x20000000, LENGTH = 64K
    /* Define output sections */
    SECTIONS
      /* The program code and other data goes into FLASH */
      .text :
            KEEP(*(.isr_vector))
        *(.text)           /* .text sections (code) */
        *(.text*)          /* .text* sections (code) */
        *(.glue_7)         /* glue arm to thumb code */
        *(.glue_7t)        /* glue thumb to arm code */
        *(.eh_frame)
        KEEP (*(.init))
        KEEP (*(.fini))
        . = ALIGN(4);
        _etext = .;        /* define a global symbols at end of code */
      } >FLASH
      /* Constant data goes into FLASH */
      .rodata :
        . = ALIGN(4);
        *(.rodata)         /* .rodata sections (constants, strings, etc.) */
        *(.rodata*)        /* .rodata* sections (constants, strings, etc.) */
        . = ALIGN(4);
      } >FLASH
      .ARM.extab   : { *(.ARM.extab* .gnu.linkonce.armextab.*) } >FLASH
      .ARM : {
        __exidx_start = .;
        *(.ARM.exidx*)
        __exidx_end = .;
      } >FLASH
      .preinit_array     :
        PROVIDE_HIDDEN (__preinit_array_start = .);
        KEEP (*(.preinit_array*))
        PROVIDE_HIDDEN (__preinit_array_end = .);
      } >FLASH
      .init_array :
        PROVIDE_HIDDEN (__init_array_start = .);
        KEEP (*(SORT(.init_array.*)))
        KEEP (*(.init_array*))
        PROVIDE_HIDDEN (__init_array_end = .);
      } >FLASH
      .fini_array :
        PROVIDE_HIDDEN (__fini_array_start = .);
        KEEP (*(SORT(.fini_array.*)))
        KEEP (*(.fini_array*))
        PROVIDE_HIDDEN (__fini_array_end = .);
      } >FLASH
      /* used by the startup to initialize data */
      _sidata = LOADADDR(.data);
      	__etext = _sidata;
      /* Initialized data sections goes into RAM, load LMA copy after code */
      .data :
        . = ALIGN(4);
        _sdata = .;        /* create a global symbol at data start */
    	__data_start__ = _sdata;
        *(.data)           /* .data sections */
        *(.data*)          /* .data* sections */
        . = ALIGN(4);
        _edata = .;        /* define a global symbol at data end */
      } >RAM AT> FLASH
      /* Uninitialized data section */
      . = ALIGN(4);
      .bss :
        /* This is used by the startup in order to initialize the .bss secion */
        _sbss = .;         /* define a global symbol at bss start */
        __bss_start__ = _sbss;
        *(.bss)
        *(.bss*)
        *(COMMON)
        . = ALIGN(4);
        _ebss = .;         /* define a global symbol at bss end */
        __bss_end__ = _ebss;
      } >RAM
        .heap (COPY):
            __end__ = .;
            PROVIDE(end = .);
            *(.heap*)
            __HeapLimit = .;
        } > RAM
        /* .stack_dummy section doesn't contains any symbols. It is only
         * used for linker to calculate size of stack sections, and assign
         * values to stack symbols later */
        .stack_dummy (COPY):
            *(.stack*)
        } > RAM
    	/* Highest address of the user mode stack */
        /* Set stack top to end of RAM, and stack limit move down by
         * size of stack_dummy section */
        __StackTop = ORIGIN(RAM) + LENGTH(RAM);
        __StackLimit = __StackTop - SIZEOF(.stack_dummy);
        PROVIDE(__stack = __StackTop);
        /* Check if data + heap + stack exceeds RAM limit */
        ASSERT(__StackLimit >= __HeapLimit, "region RAM overflowed with stack")
      /* Remove information from the standard libraries */
      /DISCARD/ :
        libc.a ( * )
        libm.a ( * )
        libgcc.a ( * )
      .ARM.attributes 0 : { *(.ARM.attributes) }
  • I am the OP in the linked question from RK. With Alpha SDK11, the merged linker script was required. Then once SDK11.0.0_89a8197 was released I still had this problem when migrating the project from the alpha SDK11 to 11.0.0_89a8197 because I did not replace the gcc_startup_nrf52.S file in my project with the one included with SDK11.0.0_89a8197
    Once I used the correct gcc_startup_nrf52.S and made sure I had my linker script search pointed to the correct directory in SDK11.0.0_89a8197 everything worked without merging the linker scripts.
