nrf52 dk use twi_sensor example exchange it to hmc5883l not work.
I wish to exchange the sensor form mma7660 to hmc5883l, so I simply replace it with my own function just like mma7660 did. Those function are
define HMC5883L_ADDR (0x1E)
define HMC5883L_REG_CONF_A (0x00) define HMC5883L_REG_CONF_B (0x01) define HMC5883L_REG_MODE (0x02) define HMC5883L_REG_X_MSB (0x03) define HMC5883L_REG_X_LSB (0x04) ...
static const nrf_drv_twi_t m_twi_hmc_5883l = NRF_DRV_TWI_INSTANCE(0);
void twi_hmc_5883l_init (void) { ret_code_t err_code;
const nrf_drv_twi_config_t twi_hmc_5883l_config = {
   .scl                = ARDUINO_SCL_PIN,
   .sda                = ARDUINO_SDA_PIN,
   .frequency          = NRF_TWI_FREQ_100K,
   .interrupt_priority = APP_IRQ_PRIORITY_HIGH
err_code = nrf_drv_twi_init(&m_twi_hmc_5883l, &twi_hmc_5883l_config, twi_hmc_5883l_handler, NULL);
nrf_drv_twi_enable(&m_twi_hmc_5883l);
void HMC5883L_set_mode(void) { ret_code_t err_code;
	uint8_t reg[3] = {0x3C, HMC5883L_REG_CONF_A, 0x70};
	uint8_t reg1[3] = {0x3C, HMC5883L_REG_CONF_B, 0xA0};
	uint8_t reg2[3] = {0x3C, HMC5883L_REG_MODE, 0x00};
err_code = nrf_drv_twi_tx(&m_twi_hmc_5883l, HMC5883L_ADDR, reg, sizeof(reg), false);
	nrf_delay_ms(100);
err_code = nrf_drv_twi_tx(&m_twi_hmc_5883l, HMC5883L_ADDR, reg1, sizeof(reg), false);
	nrf_delay_ms(100);
	err_code = nrf_drv_twi_tx(&m_twi_hmc_5883l, HMC5883L_ADDR, reg2, sizeof(reg), false);
while(m_set_mode_done == false);
and I can get callback NRF_DRV_TWI_EVT_DONE,
  1. Why the mma7660 address use (0x98U >> 1) in define, I will not get NRF_DRV_TWI_EVT_DONE if I define hmc5883l as (0x1EU >> 1)?
  2. the other question is: After I get callback and I wish to print my data,but it's all zero!!!
That confuse me....
I need help thx a lot.
  • Hi, I think you should get a logic analyzer if you haven't already. There you could see if the compass ic acknowledge the twi communication or not. In this case I think the twi address you have defined for hmc5883l is wrong, it should be hmc5883l as (0x3CU >> 1).
  • Thx for ur answer, after I change the address data start send to my dk.
  • Hi, I am also working with the HMC5883L. Do you mind sharing your code of how to read from the sensors? I have set it up equally to you and confirmed communication with the logic analyzer, however, I do not know how to read.
  • @LJohn: This code I simply try to let i2c work and make sure that data return, so u need to define the data u received.
    main.c
  • Thanks, do I assume correctly that in line: 444 you specify at which address you want to start reading the registers by defining uint8_t reg = 0x06; If i want to start reading from address 0x03, do I have to adjust this value?
1 2
