DFU with NRF52 and Segger Embedded Studio
So having first used Kiel, then Eclipse, it was great to finally ditch my clunky windows laptop with its terribly laid out keyboard by making the transition to Segger Embedded Studio. Super easy to set up, looks great on my very large Mac screen and I can now use a keyboard where I don't have to keep checking where the keys are.
Well done Segger and Nordic for making this available.
Anyway, so I have been happily setting up the solutions and going through some of the tutorials like a hot knife through butter thinking this was a piece of cake, especially compared to the time it took to get my head around Eclipse, I came to a grinding halt with the tutorial for setting up the DFU on the nRF51 DK.
I navigated the first issue regarding changing the Omit Frame Pointer to yes for Bootloader_util.c, which got it compiled ok.
However, the issue I have is with the Section Placement Macros. I am using SD 132 V2.0 and am on the pca10040. I have been scraping the App placement addresses from the armgcc .ld script (anyway, these don't change for the other BLE examples so I almost have it memorised). I thought if I set the script for the flash start to be 0x07A000 (top of the memory layout where the DFU Bootloader resides) that will be putting the Bootloader where it needs to go (I am using fu_single_bank_serial_s132). And if I leave Ram at 0x20002080 then at least I have left space for the SoftDevice. Already my logic is starting to flake.
So instead of battling against something that may prove impossible I thought I would pause and ask some questions that someone might be able to help with:
  1. Is it indeed possible to use SES in flash the SD and the DFU Bootloader in this manner (and ultimately with the App too) or am I barking up the wrong tree?
  2. Depending on 1, of course, what should the Section Placement Macros be?
  3. And, is there anything else I need to be aware of trying to use SES to do this that I have not yet uncovered (bearing in mind I want to introduce an App that will be logging significant data into the equation as well)?
Thank you everyone - RJH
  • Hey,
    I've used SEGGER Embedded Studio with DFU apps so we'll figure this out.
    First problem with the compile error in bootloader_util.c. I ran into this at well. I believe it is a GCC problem. Setting the -fomit-frame-pointer flag in the compiler settings fixes it as you have discovered.
    1.) Yes this is possible. I was doing some DFU stuff and Embedded Studio was great because of how easy it was to flash the SoftDevice, Bootloader and application at once. (Remember when you flash the application along with the SD and BL instead of updating it via DFU you need to write a flag to tell the BL there is a valid application in flash already that it should run).
    2.) Section placement macros should not be complicated. Should be the same as you would see in Keil project settings or the GCC linkers you've been looking at.
    Now there are two scenarios:
    Is your project an application with DFU capabilities or are you working on the actual bootloader?
    If working on an application with DFU you shouldn't have to do anything special. Just make sure the section placement macros have FLASH_START and SRAM_START defined the same as they would for any application with a SoftDevice present. (This is [0x1C000, 0x20002080] I believe for the s132 2.0 SD but double check). These shouldn't change at all for DFU because the bootloader is located at the end of FLASH (and RAM doesn't change at all).
    The tricky part: You can't just flash the SoftDevice, application and bootloader at once. The straight forward way I suggest you try first is flash the Softdevice and bootloader using nrfjprog or a similar tool. Then upload the application you compile in Embedded Studio to your board via the DFU process (using master control panel on PC or mobile app probably). This should work.
    But this is a pain for developing! More info on the dev zone about this: devzone.nordicsemi.com/.../. But its not as complicated as they make it in that thread so don't read to much..
    1.) Flash the softdevice, application and bootloader all at once (don't run the cpu yet though). 2.) Write the flag in memory telling the bootloader a valid application is already present in flash and that it should run that. This is one word in flash. And this can be done either with nrfjprog or you can flash a hex file that programs the one word: github.com/.../bootloader_settings_nrf52.hex
    So if you use the hex file I attached then you can automate your process nicely in Embedded Studio: flash the sd.hex, app.hex, bl.hex, bootloader_setting_nrf52.hex and then reset and run the program. It should work now! And remember in Debugger->Loader Options you can have 4 files loaded every time you program the board so this is perfect!
    If you are working on an actual bootloader its straightforward: Just set the FLASH_START to 0x7A000 or something like that. And I forget about RAM start but jsut double check Keil and GCC projects.
    -Mike
  • @nateperry : You can set the valid application flag in the bootloader settings by editing the following line in bootloader_settings.c form
    uint8_t m_boot_settings[CODE_PAGE_SIZE] __attribute__ ((section(".bootloaderSettings")));
    to
    uint8_t m_boot_settings[CODE_PAGE_SIZE] __attribute__ ((section(".bootloaderSettings"))) = {BANK_VALID_APP};
    and setting the .bootloaderSettings sectoni to load="Yes" in the flash placement xml.file. I have attached the Memory Map and Flash placment files below.
    nRF52832_xxAA_MemoryMap.xml
    flash_placement.xml
    to
    flash_placement.xml
