Connect two nordic devices and send data via UART to PC
Hi all Nordic developers,
I am currently working on an application using a sensor (the temperature sensor) on a Smart beacon kit, which must connect and send data to a nRF51 DK; for this no problem, i already have done everything using some code (ble app multilink in particular) and it's working. After this, i want the received data by the DK to be sent via UART to the PC, which is of course connected by USB to my DK board. How can i do this? I have already tried to implement some part of the ble_app_uart example, just the part that should initialize the uart service and send data via the function "uart put", but i must be missing something because if i launch it, it conflicts with the multilink part of the code and the DK board doesn't even connect to the beacon, if i comment the "uart_init" function in main, everything returns functional. What am i missing in implementing the UART part? I post the full code, but the uart portion is just the last quarter of the code, i wrote a comment when it starts. Thanks in advance!
 * Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
 * The information contained herein is confidential property of Nordic Semiconductor. The use,
 * copying, transfer or disclosure of such information is prohibited except by express written
 * agreement with Nordic Semiconductor.
 * @brief BLE LED Button Service central and client application main file.
 * This example can be a central for up to 8 peripherals.
 * The peripheral is called ble_app_blinky and can be found in the ble_peripheral
 * folder.
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "softdevice_handler.h"
#include "app_timer.h"
#include "app_trace.h"
#include "boards.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "app_uart.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
#include "ble_lbs_c.h"
#include "ble_conn_state.h"
#include "nrf_log.h"
#include "nrf.h"
#include "ble_hci.h"
#include "app_button.h"
#include "ble_nus.h"
#define IS_SRVC_CHANGED_CHARACT_PRESENT 0                                           /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
#define CENTRAL_LINK_COUNT        1                                          /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
#define PERIPHERAL_LINK_COUNT     1                                          /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
#define TOTAL_LINK_COUNT          CENTRAL_LINK_COUNT + PERIPHERAL_LINK_COUNT /**< Total number of links used by the application. */
#define APPL_LOG                  app_trace_log                              /**< Macro used to log debug information over UART. */
#define CENTRAL_SCANNING_LED      BSP_LED_0_MASK
#define CENTRAL_CONNECTED_LED     BSP_LED_1_MASK
#define APP_TIMER_PRESCALER       0                                          /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_MAX_TIMERS      (2+BSP_APP_TIMERS_NUMBER)                  /**< Maximum number of timers used by the application. */
#define APP_TIMER_OP_QUEUE_SIZE   2                                          /**< Size of timer operation queues. */
#define SCAN_INTERVAL             0x00A0                                     /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW               0x0050                                     /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_TIMEOUT              0x0000                                     /**< Timout when scanning. 0x0000 disables timeout. */
#define SCAN_REQUEST              0                                          /**< Active scannin is not set. */
#define SCAN_WHITELIST_ONLY       0                                          /**< We will not ignore unknown devices. */
#define MIN_CONNECTION_INTERVAL   MSEC_TO_UNITS(7.5, UNIT_1_25_MS)           /**< Determines minimum connection interval in milliseconds. */
#define MAX_CONNECTION_INTERVAL   MSEC_TO_UNITS(30, UNIT_1_25_MS)            /**< Determines maximum connection interval in milliseconds. */
#define SLAVE_LATENCY             0                                          /**< Determines slave latency in terms of connection events. */
#define SUPERVISION_TIMEOUT       MSEC_TO_UNITS(4000, UNIT_10_MS)            /**< Determines supervision time-out in units of 10 milliseconds. */
#define UUID16_SIZE               2                                          /**< Size of a UUID, in bytes. */
#define LEDBUTTON_LED             BSP_LED_2_MASK                             /**< LED to indicate a change of state of the the Button characteristic on the peer. */
#define LEDBUTTON_BUTTON_PIN      BSP_BUTTON_0                               /**< Button that will write to the LED characteristic of the peer */
#define BUTTON_DETECTION_DELAY    APP_TIMER_TICKS(50, APP_TIMER_PRESCALER)   /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
static const char m_target_periph_name[] = "Macaque";                  /**< Name of the device we try to connect to. This name is searched for in the scan report data*/
static ble_nus_t                        m_nus;                                      /**< Structure to identify the Nordic UART Service. */
static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static ble_uuid_t                       m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};  /**< Universally unique service identifier. */
/** @brief Scan parameters requested for scanning and connection. */
static const ble_gap_scan_params_t m_scan_param =
    SCAN_REQUEST,
    SCAN_WHITELIST_ONLY,
    NULL,
    (uint16_t)SCAN_INTERVAL,
    (uint16_t)SCAN_WINDOW,
    SCAN_TIMEOUT
/**@brief Connection parameters requested for connection. */
static const ble_gap_conn_params_t m_connection_param =
    (uint16_t)MIN_CONNECTION_INTERVAL,
    (uint16_t)MAX_CONNECTION_INTERVAL,
    (uint16_t)SLAVE_LATENCY,
    (uint16_t)SUPERVISION_TIMEOUT
static ble_lbs_c_t        m_ble_lbs_c[TOTAL_LINK_COUNT];           /**< Main structures used by the LED Button client module. */
static uint8_t            m_ble_lbs_c_count;                       /**< Keeps track of how many instances of LED Button client module have been initialized. >*/
static ble_db_discovery_t m_ble_db_discovery[TOTAL_LINK_COUNT];    /**< list of DB structures used by the database discovery module. */
/**@brief Function to handle asserts in the SoftDevice.
 * @param[in] line_num     Line number of the failing ASSERT call.
 * @param[in] p_file_name  File name of the failing ASSERT call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for the LEDs initialization.
 * @details Initializes all LEDs used by the application.
static void leds_init(void)
    LEDS_CONFIGURE(CENTRAL_SCANNING_LED | CENTRAL_CONNECTED_LED | LEDBUTTON_LED);
    LEDS_OFF(CENTRAL_SCANNING_LED | CENTRAL_CONNECTED_LED | LEDBUTTON_LED);
 * @brief Parses advertisement data, providing length and location of the field in case
 *        matching data is found.
 * @param[in]  type       Type of data to be looked for in advertisement data.
 * @param[in]  p_advdata  Advertisement report length and pointer to report.
 * @param[out] p_typedata If data type requested is found in the data report, type data length and
 *                        pointer to data will be populated here.
 * @retval NRF_SUCCESS if the data type is found in the report.
 * @retval NRF_ERROR_NOT_FOUND if the data type could not be found.
static uint32_t adv_report_parse(uint8_t type, uint8_array_t * p_advdata, uint8_array_t * p_typedata)
    uint32_t  index = 0;
    uint8_t * p_data;
    p_data = p_advdata->p_data;
    while (index < p_advdata->size)
        uint8_t field_length = p_data[index];
        uint8_t field_type   = p_data[index + 1];
        if (field_type == type)
            p_typedata->p_data = &p_data[index + 2];
            p_typedata->size   = field_length - 1;
            return NRF_SUCCESS;
        index += field_length + 1;
    return NRF_ERROR_NOT_FOUND;
/**@brief Function to start scanning.
static void scan_start(void)
    ret_code_t err_code;
    err_code = sd_ble_gap_scan_stop();
    // It is okay to ignore this error since we are stopping the scan anyway.
    NRF_LOG_PRINTF("[APP]: start scanning for device name %s\r\n", m_target_periph_name);
    err_code = sd_ble_gap_scan_start(&m_scan_param);
/**@brief Handles events coming from the LED Button central module.
 * @param[in] p_lbs_c     The instance of LBS_C that triggered the event.
 * @param[in] p_lbs_c_evt The LBS_C event.
static void lbs_c_evt_handler(ble_lbs_c_t * p_lbs_c, ble_lbs_c_evt_t * p_lbs_c_evt)
    const uint16_t conn_handle = p_lbs_c_evt->conn_handle;
    switch (p_lbs_c_evt->evt_type)
        case BLE_LBS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_PRINTF("[APP]: LED Button service discovered on conn_handle 0x%x\r\n",
                            conn_handle);
            err_code = app_button_enable();
            // LED Button service discovered. Enable notification of Button.
            err_code = ble_lbs_c_button_notif_enable(p_lbs_c);
        } break; // BLE_LBS_C_EVT_DISCOVERY_COMPLETE
        case BLE_LBS_C_EVT_BUTTON_NOTIFICATION:
            NRF_LOG_PRINTF("[APP]: Link 0x%x, Button state changed on peer to 0x%x\r\n",
                           conn_handle,
                           p_lbs_c_evt->params.button.button_state);
            if (p_lbs_c_evt->params.button.button_state)
                LEDS_ON(LEDBUTTON_LED);
                LEDS_OFF(LEDBUTTON_LED);
        } break; // BLE_LBS_C_EVT_BUTTON_NOTIFICATION
            // No implementation needed.
/**@brief Function for handling the advertising report BLE event.
 * @param[in] p_ble_evt  Bluetooth stack event.
static void on_adv_report(const ble_evt_t * const p_ble_evt)
    uint32_t      err_code;
    uint8_array_t adv_data;
    uint8_array_t dev_name;
    bool          do_connect = false;
    // For readibility.
    const ble_gap_evt_t * const p_gap_evt    = &p_ble_evt->evt.gap_evt;
    const ble_gap_addr_t  * const peer_addr  = &p_gap_evt->params.adv_report.peer_addr;
    // Initialize advertisement report for parsing
    adv_data.p_data = (uint8_t *)p_gap_evt->params.adv_report.data;
    adv_data.size   = p_gap_evt->params.adv_report.dlen;
    //search for advertising names
    bool found_name = false;
    err_code = adv_report_parse(BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME,
                                &adv_data,
                                &dev_name);
    if (err_code != NRF_SUCCESS)
        // Look for the short local name if it was not found as complete
        err_code = adv_report_parse(BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME, &adv_data, &dev_name);
            // If we can't parse the data, then exit
            return;
            found_name = true;
        found_name = true;
    if (found_name)
        if (strlen(m_target_periph_name) != 0)
            if(memcmp(m_target_periph_name, dev_name.p_data, dev_name.size) == 0)
                do_connect = true;
    if (do_connect)
        // Initiate connection.
        err_code = sd_ble_gap_connect(peer_addr, &m_scan_param, &m_connection_param);
            APPL_LOG("[APPL]: Connection Request Failed, reason %d\r\n", err_code);
/**@brief Function for handling BLE Stack events concerning central applications.
 * @details This function keeps the connection handles of central applications up-to-date. It
 *          parses scanning reports, initiating a connection attempt to peripherals when a
 *          target UUID is found, and manages connection parameter update requests. Additionally,
 *          it updates the status of LEDs used to report central applications activity.
 * @note Since this function updates connection handles, @ref BLE_GAP_EVT_DISCONNECTED events
 *       should be dispatched to the target application before invoking this function.
static void on_ble_evt(const ble_evt_t * const p_ble_evt)
    // For readability.
        // Upon connection, check which peripheral has connected, initiate DB
        // discovery, update LEDs status and resume scanning if necessary.
        case BLE_GAP_EVT_CONNECTED:
            uint32_t err_code;
            NRF_LOG_PRINTF("[APP]: link 0x%x established, start discovery on it\r\n",
                           p_gap_evt->conn_handle);
            APP_ERROR_CHECK_BOOL(p_gap_evt->conn_handle < TOTAL_LINK_COUNT);
            err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c[p_gap_evt->conn_handle],
                                                p_gap_evt->conn_handle,
                                                NULL);
            err_code = ble_db_discovery_start(&m_ble_db_discovery[p_gap_evt->conn_handle],
            if (err_code != NRF_ERROR_BUSY)
            // Update LEDs status, and check if we should be looking for more
            // peripherals to connect to.
            LEDS_ON(CENTRAL_CONNECTED_LED);
            if (ble_conn_state_n_centrals() == CENTRAL_LINK_COUNT)
                LEDS_OFF(CENTRAL_SCANNING_LED);
                // Resume scanning.
                LEDS_ON(CENTRAL_SCANNING_LED);
                scan_start();
        } break; // BLE_GAP_EVT_CONNECTED
        // Upon disconnection, reset the connection handle of the peer which disconnected, update
        // the LEDs status and start scanning again.
            uint32_t central_link_cnt; // Number of central links.
            NRF_LOG_PRINTF("LBS central link 0x%x disconnected (reason: %d)\r\n",
                           p_gap_evt->params.disconnected.reason);
            uint32_t err_code = app_button_disable();
            // Start scanning
            scan_start();
            // Update LEDs status.
            central_link_cnt = ble_conn_state_n_centrals();
            if (central_link_cnt == 0)
                LEDS_OFF(CENTRAL_CONNECTED_LED);
        } break; // BLE_GAP_EVT_DISCONNECTED
        case BLE_GAP_EVT_ADV_REPORT:
            on_adv_report(p_ble_evt);
        break; // BLE_GAP_ADV_REPORT
        case BLE_GAP_EVT_TIMEOUT:
            // We have not specified a timeout for scanning, so only connection attemps can timeout.
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                APPL_LOG("[APPL]: Connection Request timed out.\r\n");
        } break; // BLE_GAP_EVT_TIMEOUT
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accept parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                        &p_gap_evt->params.conn_param_update_request.conn_params);
        } break; // BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST
/**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
 * @details This function is called from the scheduler in the main loop after a BLE stack event has
 * been received.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    uint16_t conn_handle;
    conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
    ble_conn_state_on_ble_evt(p_ble_evt);
        ble_nus_on_ble_evt(&m_nus, p_ble_evt);
    // Make sure taht an invalid connection handle are not passed since
    // our array of modules is bound to TOTAL_LINK_COUNT.
    if (conn_handle < TOTAL_LINK_COUNT)
        ble_db_discovery_on_ble_evt(&m_ble_db_discovery[conn_handle], p_ble_evt);
        ble_lbs_c_on_ble_evt(&m_ble_lbs_c[conn_handle], p_ble_evt);
/**@brief LED Button collector initialization.
static void lbs_c_init(void)
    uint32_t         err_code;
    ble_lbs_c_init_t lbs_c_init_obj;
    lbs_c_init_obj.evt_handler = lbs_c_evt_handler;
    for(m_ble_lbs_c_count = 0; m_ble_lbs_c_count < TOTAL_LINK_COUNT; m_ble_lbs_c_count++)
        err_code = ble_lbs_c_init(&m_ble_lbs_c[m_ble_lbs_c_count], &lbs_c_init_obj);
 * @details Initializes the SoftDevice and the BLE event interrupts.
    nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
    // Initialize the SoftDevice handler module.
    SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
    ble_enable_params_t ble_enable_params;
    err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                    PERIPHERAL_LINK_COUNT,
                                                    &ble_enable_params);
    // Stack checks first if there are still entries in the table before checking if a vendor
    // specific UUID is already in the table thus to be able to call sd_ble_uuid_vs_add several
    // times with the same entry, vs_uuid_count has to be 1 bigger than what is actually needed.
    ble_enable_params.common_enable_params.vs_uuid_count = 2;
    // Check the ram settings against the used number of links
    CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
    // Enable BLE stack.
    err_code = softdevice_enable(&ble_enable_params);
    // Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
/**@brief Function to write to the LED characterestic of all connected clients.
 * @details Based on if the button is pressed or released, we write a high or low LED status to
 *          the server.
 * @param[in] button_action The button action (press/release).
 *            Determines if the LEDs of the servers will be ON or OFF.
 * @return NRF_SUCCESS on success, else the error code from ble_lbs_led_status_send.
static uint32_t led_status_send_to_all(uint8_t button_action)
    uint32_t err_code;
    for (uint32_t i = 0; i< CENTRAL_LINK_COUNT; i++)
        err_code = ble_lbs_led_status_send(&m_ble_lbs_c[i], button_action);
        if (err_code != NRF_SUCCESS &&
            err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
            err_code != NRF_ERROR_INVALID_STATE)
            return err_code;
        return NRF_SUCCESS;
/**@brief Function for handling events from the button handler module.
 * @param[in] pin_no        The pin that the event applies to.
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
    uint32_t err_code;
    switch (pin_no)
        case LEDBUTTON_BUTTON_PIN:
            err_code = led_status_send_to_all(button_action);
            if (err_code == NRF_SUCCESS)
                NRF_LOG_PRINTF("LBS write LED state %d\r\n", button_action);
            APP_ERROR_HANDLER(pin_no);
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
    uint32_t err_code;
   //The array must be static because a pointer to it will be saved in the button handler module.
    static app_button_cfg_t buttons[] =
        {LEDBUTTON_BUTTON_PIN, false, BUTTON_PULL, button_event_handler}
    err_code = app_button_init(buttons, sizeof(buttons) / sizeof(buttons[0]),
                               BUTTON_DETECTION_DELAY);
/**@brief Function for handling database discovery events.
 * @details This function is callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function should forward the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    NRF_LOG_PRINTF("[APP]: call to ble_lbs_on_db_disc_evt for instance %d and link 0x%x!\r\n",
                    p_evt->conn_handle,
    ble_lbs_on_db_disc_evt(&m_ble_lbs_c[p_evt->conn_handle], p_evt);
/** @brief Database discovery initialization.
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
/** @brief Function to sleep until a BLE event is received by the application.
static void power_manage(void)
    ret_code_t err_code = sd_app_evt_wait();
***// HERE STARTS THE UART PART!!!!!***
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_nus    Nordic UART Service structure.
 * @param[in] p_data   Data to be send to UART module.
 * @param[in] length   Length of the data.
/**@snippet [Handling the data received over BLE] */
static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
    for (uint32_t i = 0; i < length; i++)
        while(app_uart_put(p_data[i]) != NRF_SUCCESS);
    while(app_uart_put('\n') != NRF_SUCCESS);
    uint32_t       err_code;
    ble_nus_init_t nus_init;
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' i.e '\n' (hex 0x0D) or if the string has reached a length of
 *          @ref NUS_MAX_DATA_LENGTH.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (BLE_NUS_MAX_DATA_LEN)))
                err_code = ble_nus_string_send(&m_nus, data_array, index);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
    const app_uart_comm_params_t comm_params =
        RX_PIN_NUMBER,
        TX_PIN_NUMBER,
        RTS_PIN_NUMBER,
        CTS_PIN_NUMBER,
        APP_UART_FLOW_CONTROL_DISABLED,
        false,
        UART_BAUDRATE_BAUDRATE_Baud38400
    APP_UART_FIFO_INIT( &comm_params,
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOW,
                       err_code);
        bool erase_bonds;
    err_code = NRF_LOG_INIT();
    NRF_LOG_PRINTF("[APP]: Multilink Example\r\n");
    leds_init();
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, NULL);
    buttons_init();
    ble_stack_init();
        //uart_init();
        services_init();
    db_discovery_init();
    lbs_c_init();
    // Start scanning for peripherals and initiate connection to devices which
    // advertise.
    scan_start();
    // Turn on the LED to signal scanning.
    for (;;)
        // Wait for BLE events.
        power_manage();
