nrf52-ble-app-lbs - main.c doesnt compile
Hi, i;m trying to build the "nrf52-ble-app-lbs" example which i downloaded from git hub github.com/NordicSemiconducto....
I followed the instructions in the README file.I'm not using any IDE. I invoked make in armgcc folder.
Compilation of main.c gives errors plenty as follows.
Kindly help.
Compiling file: main.c
../../../main.c: In function 'timers_init':
../../../main.c:124:98: error: macro "APP_TIMER_APPSH_INIT" passed 4 arguments, but takes just 3
     APP_TIMER_APPSH_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, true);
../../../main.c:124:5: error: 'APP_TIMER_APPSH_INIT' undeclared (first use in this function)
../../../main.c:124:5: note: each undeclared identifier is reported only once for each function it appears in
../../../main.c: In function 'on_ble_evt':
../../../main.c:341:5: error: unknown field 'keys_periph' specified in initializer
     static ble_gap_sec_keyset_t      m_keys = {.keys_periph = {&m_enc_key, &m_id_key, &m_sign_key}};
../../../main.c:396:48: error: 'ble_gap_evt_auth_status_t {aka struct <anonymous>}' has no member named 'kdist_periph'
             p_distributed_keys = &m_auth_status.kdist_periph;
../../../main.c:331:38: error: variable 'm_auth_status' set but not used [-Werror=unused-but-set-variable]
     static ble_gap_evt_auth_status_t m_auth_status;
In file included from ../../../main.c:36:0:
../../../main.c: In function 'ble_stack_init':
../../../main.c:456:29: error: 'NRF_CLOCK_LFCLKSRC_XTAL_20_PPM' undeclared (first use in this function)
     SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, NULL);
../../../../../../components/softdevice/common/softdevice_handler/softdevice_handler.h:97:45: note: in definition of macro 'SOFTDEVICE_
HANDLER_INIT'
         ERR_CODE = softdevice_handler_init((CLOCK_SOURCE),                                         \
../../../main.c:466:16: error: too few arguments to function 'sd_ble_enable'
     err_code = sd_ble_enable(&ble_enable_params);
In file included from ../../../../../../components/softdevice/s132/headers/ble_gap.h:48:0,
                 from ../../../../../../components/softdevice/s132/headers/ble.h:52,
                 from ../../../main.c:29:
../../../../../../components/softdevice/s132/headers/ble.h:401:33: note: declared here
 SVCALL(SD_BLE_ENABLE, uint32_t, sd_ble_enable(ble_enable_params_t * p_ble_enable_params, uint32_t * p_app_ram_base));
../../../../../../components/softdevice/s132/headers/nrf_svc.h:64:22: note: in definition of macro 'SVCALL'
   static return_type signature                          \
cc1.exe: all warnings being treated as errors
make: *** [_build/main.o] Error 1
