Can i use sd_ble_gatts_hvx function in freertos custom thread?
the priority of my custom thread is lowest priority. but it's not possible to call hvx function.
in ble_app_hrs_freertos example,
a sd_ble_gatts_hvx function is called in timer service routine context.
that's ok. because interrupt service routine.
i know that a interupt servie routine context same to main in freertos.
So, is it possible to only call a sd_ble_gatts_hvx function in main context or interrupt context????
if it is not, please show me example.
  • I just tested it and it seems to work:
    main.c
    Is there something different with your setup?
  • Thanks for reply. I tested your example code. and it's good.
    but in my project, the hardfault is occured.
    So, i checked again my code. before calling hvx function, my code use a floating point operation.
    my project base is nRF5_SDK_11.0.0-2.alpha_bc3f6a0.
    I chaned a base sdk to nRF5_SDK_11.0.0_89a8197.
    then hardfault disappeared.
    i don't know the cause.
    in nRF5_SDK_11.0.0-2.alpha_bc3f6a0 , do you have a FPU problem in freertos?
    i would like to know the cause.
  • We have seen problems with FPU and FreeRTOS with SDK 0.9.2 and SoftDevice S132 v1, but not with SDK 11.0.0-2.alpha and S132 v2.0.0-7.alpha. I am not able to reproduce the error here.
