make: Circular flash <- flash dependency dropped.
I am trying to flash TCP-Server example from IOT SDK from Eclipse. Project builds without errors. But I am getting this warning message in Eclipse console when I flash to nRF52 DK:
Apparently the project is not flashing correctly - I do not see lit advertisement LED.
I use nrf52832_xxaa_s1xx_iot soft device as stated in Makefile (make target: flash nrf52832_xxaa_s1xx_iot). Everything works fine except that warning above. The target execution ends with the following:
Applying system reset.
Checking that the area to write is not protected.
Programing device.
nrfjprog --reset
Run.
make: `nrf52832_xxaa_s1xx_iot' is up to date.
But documentation for this examle says:
Ensure the custom SoftDevice located at components/softdevice/s110_for_ipv6 is used.
I could not find this softdevice.
I also do not have advertising LED on when I program the DK using nrfjprog from terminal.
Please suggest what I should do to make the example running. Thank you.
