Is there a link where I can find all sources of applications for NRF51822 corresponding at iOS App "nRF Utility" (with explanations of use of both systems)?
Thanks for the reply ;-)
The source code for most of this app is available from this page, but it is built with the Wahoo Framework. However, all our other iOS apps are available with full source code, so it might be useful to take a look at them.
Also, Apple's Core Bluetooth Programming Guide should be useful to refer to.
Edit: If you're looking for nRF51822 applications that can work with the different parts of this iOS app, you should refer to the nRF51 SDK. There are no direct mapping between them, but by looking at the description for the different applications in the SDK documentation, it shouldn't be hard to map out which is which.
Probably I have not explained well (my english is bad ;) I have no problems with iOS. My request is for a dialogue between software written for NRF51822 in connection with the iOS App .. NRF51822 work if controlled by the "Master Control Panel". I wanted to see the differences between the two systems. For this I need to have the correct sources for NRF51822 ..
Sorry for misunderstanding, I expanded my answer a little.
