In nrf52_SDK/examples/peripherals/rtc we tried adding the UART prints and verified. It was working fine for RTC0 but fails to do for RTC1. Could you please give any hint on this?
I changed the following for using RTC1,
As per the example, LED0 should blink for every ticks and LED 1 should be ON after 3 seconds. This happened for RTC0 and RTC2. But this did not happened for RTC1.
For the particular example, you will see that RTC0 is configured like this, in examples\peripheral\rtc\config\rtc_pca10036\nrf_drv_config.h (or the equivalent for your SDK version and board):
#define RTC0_CONFIG_FREQUENCY 8
This means to get the same behaviour (the same blinking frequency) when using RTC1, you must set RTC1_CONFIG_FREQUENCY to 8:
#define RTC1_CONFIG_FREQUENCY 8
For other examples, as well as in the default nrf_drv_config.h file, there is an error on line 104:
#define RTC1_CONFIG_FREQUENCY 32678
It should rather be:
#define RTC1_CONFIG_FREQUENCY 32768
This was a typo in the SDK. It does not however apply for the peripheral\rtc\ example, and it may be correctly set for some of the other examples as well.
Regards, Terje
sorry, I forgot to mention. I did the above change too.
Ok,
