I am using nRF51822 spi as a master to communicate with the AFE. Four bytes need to transfer each read or write process. I use nRF51_SDK_10.0.0_dc26b5e.
Configuration:
NOTE: Blocking mode is used void spi_master_init(void) { uint32_t err_code = NRF_SUCCESS;
nrf_drv_spi_config_t config =
.ss_pin = NRF_DRV_SPI_PIN_NOT_USED,
.irq_priority = APP_IRQ_PRIORITY_LOW,
.orc = 0x00,
.frequency = NRF_DRV_SPI_FREQ_1M,
.mode = NRF_DRV_SPI_MODE_0,
.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST,
config.sck_pin = SPI0_CONFIG_SCK_PIN;
config.mosi_pin = SPI0_CONFIG_MOSI_PIN;
config.miso_pin = SPI0_CONFIG_MISO_PIN;
err_code = nrf_drv_spi_init(&m_spi_master_0, &config, NULL); // If NULL, transfers will be performed in blocking mode
Send process:
uint32_t set_afe_reg_value(uint8_t num_register, uint32_t register_value) { uint8_t spi_tx_buf[4]; uint8_t dummy_rx_buf[4];
uint32_t err_code;
/* Set SPI transmit buffer */
spi_tx_buf[0] = num_register; // Address
spi_tx_buf[1] = (uint8_t) ((register_value >> 16) & 0xFF); // Data[23..16]
spi_tx_buf[2] = (uint8_t) ((register_value >> 8) & 0xFF); // Data[15..9]
spi_tx_buf[3] = (uint8_t) ((register_value) & 0xFF); // Data[7..0]
/* Set chip select signal active before SPI transfer */
nrf_drv_gpiote_out_clear(SPI0_AFE_CS_PIN);
/* Start SPI transfer */
err_code = nrf_drv_spi_transfer(&m_spi_master_0, spi_tx_buf, 4, dummy_rx_buf, 4);
/* De-select chipset */
nrf_drv_gpiote_out_set(SPI0_AFE_CS_PIN);
return err_code;
The tested code:
set_afe_reg_value(AFE_REG0, 0x00000001);
set_afe_reg_value(AFE_REG1, 0x00001010);
there is a delay(not short) between the third bytes transmit and fourth byte during the second set register value process as shown below:(/attachment/9319e775c3ae331f05fd75f7b4169ad8)
