Hi all,
I have to transfer a lot of data over the UART channel, and run into some problems...
First problem was/is the UART FIFO Size. There are three different defines on the SDK for the RX/TX buffers:
#define TX_BUF_SIZE 600u
#define RX_BUF_SIZE TX_BUF_SIZE
#define RX_BUF_QUEUE_SIZE 4u
#define TX_BUF_SIZE 4u
#define RX_BUF_SIZE 32u
#define RX_BUF_QUEUE_SIZE 8u
#define TX_BUF_SIZE 32u
#define RX_BUF_SIZE 600u
#define RX_BUF_QUEUE_SIZE 2u
My block is 512bytes long in data plus 3bytes of header and 1byte of checksum. My first attemp was to use 520bytes of buffer, which resulted in unpredictable behaviour from the NRF51822. Further reading on the documentation, I then realised that the size has to be a power of 2... So how can one expect a reliable behaviour of using 600 bytes (from the builtin defines of the SDK's). If my math is not that bad, there is no power of 2 that gives 600... Unless the exponent part can be decimal (???)...
I now run my fifo with a 1024byte size (from which I'll be only using the 516 bytes above), and it seems to be working... At least my data seems to be travelling ok to the end-point. What is the maximum value of the fifo size one can use? Can I expect reliability from my device while using this 1024 fifo? Again I will be transferring 516 bytes (I have implemented software hand-shake to get more data only once the previous packet as been successfully sent).
Using sizes different from a power of 2 resulted in different behaviour depending on the size of the buffer and the board (tested it across several boards).
From what I can see, there are a lot of UART related problems throughout the forum, when the fifo size starts growing, which I recon can be related to this problem.
Last I can provide some other info about my setup (which I think don't really interfere with this behaviour): SDK 8.1.1 SD130 v1.0.0 NRF51822XXAC REV3
Thanks in advance, Diogo
