Is it the channel table of the Gazell are the same as the DTM, but the Gazell have 0 - 125 channel and the DTM only have the 0 - 39? Please advise.
Hi Steven
Gazell does not use the same channels as DTM.
DTM uses the BLE channels, which are spaced 2 MHz apart and start at 2402MHz.
Gazell uses the proprietary channels available from 2400-2425MHz, with 1MHz spacing.
Please be aware that you should probably stick to Gazell channels 2-82 if you don't want to risk going outside the ISM band.
Best regards
Torbjørn
