nrf52 Low temperature issue
I am using nRF52832 with SDK 11.0.0 and S132_V2.0.0 for my application. My beacon is inside Refrigerator where temperature varies from -2 to 20 degree.My Beacon code is in Pheripheral mode.
I have found following issue with my hardware.
If I put hardware in Refrigerator then I found that at low temperature(< 0 degree) after some time advertisement goes off. If I took out hardware out of cooler then after some time it starts advertisement again. Please note I have enabled internal DC to DC converter in nRF52. One thing i have done that i have disable DC to DC converter and test again in cooler then advertisement doesn't go off and works ok. But that to is not 100% reliable.
Same thing when i try with third party nRf51 module all is working good. I am keeping both nRf51/52 Beacons inside refrigerator. After sometime nRf52 stops advertising but nRf51 is working good whole day at +-2 Degree celsius.
Now when i expose this nRf52 hardware at room temperature then its working good. Its advertising as well as connecting whole day.
So i am bit confuse why this thing is not working at 0 degree celsius, Since as per data sheet it should work upto -40 degree celsius.
Even all the components which i have used in this Beacon Hardware all can work upto -40 to 75 degree celsius.
A quick reply would be quite helpful..
