nRF51 SDK pstorage bug: bad memory access
I'm using nRF51 SDK v 5.1.0 with SoftDevice v6.0.0 on nRF51822.
I'm using the pstorage SDK module for flash operations.
I've found an issue with this module, a bad memory access leading to a hardfault.
The issue occurs when the pstorage command queue is never completely empty, and the application keeps posting flash operation requests to the module while previous operations are processed.
The internal command array is used as a circular buffer, cf internal cmd_queue_enqueue() function:
if (m_cmd_queue.count != PSTORAGE_CMD_QUEUE_SIZE)
    // Enqueue the command if it is queue is not full
    write_index = m_cmd_queue.rp + m_cmd_queue.count;
    if (write_index >= PSTORAGE_CMD_QUEUE_SIZE)
        write_index -= PSTORAGE_CMD_QUEUE_SIZE;
    /* The request is then stored into the queue at write_index */
However, when a command is dequeued, the index is not checked, cf cmd_queue_dequeue():
f(m_round_val >= p_cmd->size)
    // Initialize/free the element as it is now processed.
    cmd_queue_init_element(m_cmd_queue.rp);
    m_round_val = 0;
    m_cmd_queue.count--;
    m_cmd_queue.rp++;
/* m_cmd_queue.rp is then directly used by further process_cmd() without checking its range */
I've attached a simple and naive testcase to reproduce the issue. I've been able to reproduce this issue on both PCA 10004 and custom board (you can find some logs in the archive).
I've also attached a suggested patch which solves the issue on the testcase. However, maybe more changes are needed which I'm not conscious of.
I'll be glad if someone could confirm the bug and / or the patch.
Thanks for your help !
Regards, Florent
pstorage-bad-mem-access.zip
pstorage-patch.zip
