Our device based on nRF51822 with SD110 v.8.0.0.
The firmware use defined area in top of the flash to store some data.
The "RAW" functions sd_flash_write
and sd_flash_page_erase
are used for flash write and erase operations correspondingly.
The next construction used for checking success of flash operation:
while (sd_evt_get(&evt_id) != NRF_ERROR_NOT_FOUND) {
if (evt_id == NRF_EVT_FLASH_OPERATION_SUCCESS){
//SUCCESS
}else if (evt_id == NRF_EVT_FLASH_OPERATION_ERROR){
//ERROR
In general, it works for a long time without any troubles.
However, is some cases both write and erase operations return success while flash area remained unchanged.
I made some investigation and nodiced some dependence of influence of power supply on actual result of flash operation. In our device we use CR2032 batteries for powering and in seem that on sligtly discharged batteries this failure behavior is more repetable.
I enabled NRF_EVT_POWER_FAILURE_WARNING
at level NRF_POWER_THRESHOLD_V25
and effect became even more noticeable because the warning notifies about the voltage drops lower than 2.5v and problem with flash taking place.
So my questions regarded:
- Is described effect investigated? Any reports?
- Why
status received if no changes in flash? Does Softdevice make verification of written/erased area? - Any workarounds except battery replacement and doing "manual" verification by reading defined area?
