GPIO Interrupt not triggered
I am trying to set up a button interrupt by adding the following functions:
void button_interrupt_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    nrf_gpio_pin_toggle(LED_4);
void button4_config()
    nrf_drv_gpiote_in_config_t config;
    memset(&config, 0, sizeof(nrf_drv_gpiote_in_config_t));
    config.sense = NRF_GPIOTE_POLARITY_HITOLO;
    config.pull = NRF_GPIO_PIN_NOPULL;
    config.hi_accuracy = false;
    config.is_watcher = false;
    nrf_drv_gpiote_in_init(BUTTON_4, &config, button_interrupt_handler);
    nrf_drv_gpiote_in_event_enable(BUTTON_4, true);
    button4_config();
When I tried to press the button, my interrupt is never called. Not even once.
Thinking that maybe the problem is because I was using BUTTON_4, I have also tried to replace it with pin 29 and use an external button. That doesn't work either.
What could I be missing?
  • I can't see that you are calling nrf_drv_gpiote_init() anywhere
    Edit 1: Try this:
    static void button4_config()
        config.pull = NRF_GPIO_PIN_PULLUP;
     * @brief Function for application main entry.
        ret_code_t err_code;
        nrf_gpio_cfg_output(LED_4);
        button4_config();
        while (true)
  • Hi Petter, I indeed missed that function call. However it is coincidentally covered when I called app_pwm_init() at an earlier point in my application, so it does not seem to be the problem.
    I have however added the call into my button4_config() as instructed in the GPIOTE driver page, however the button interrupt is still not called.
  • Hi Petter,
    Sorry for being late with the follow up. I just got out of a very tight deadline rush.
    I have tried explicitly calling the function nrf_drv_gpiote_init() as you shown in your code. However that does not help. It returns NRF_ERROR_INVALID_STATE indicating that GPIOTE has already been initialized by something else.
  • Also, my application is based off of the ble_app_uart example so during setup it also call:
    uint32_t err_code = bsp_init(BSP_INIT_LED /* | BSP_INIT_BUTTONS */,
                                     APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                     bsp_event_handler);
    Perhaps this matters? I tried remove | BSP_INIT_BUTTON from the parameter and managed to make the button works somehow. However, it seems the button is extremely sensitive, just my hand touching it causes LED 4 to blink rapidly.
  • *update: fixed that extreme sensitivity issue. Turns out I should have the GPIO pin being pulled up, so I did just that.
    So my new question would be, is it impossible to overwrite the button behavior set by bsp_init()?
