Master Emulator go crazy after a connect fail
I'm using the Master Emulator DLL to build a VB, everything seems go fine. However I found that if there's a device discovered but fail to connect by some result (eg. if the device just shut off the BLE; or if it's too far away). Once connection failed, it cannot start device discovery again. Whenever I start discovery after such condition, the masterEmulator.StartDeviceDiscovery will also return FALSE. The only thing I can do is quite the program and re-start it.
I can also repeat the problem by NetworkAvailabilityDemo example code.
So, is there anyway I can do to "recover" such condition?
I'm using the latest DLL (2.1.13.14), x86 version, using the PCA10031 dongle.
My code about the discovery is:
'Start discovery
Public Sub startDeviceDiscovery()
    Dim scanPara As BtScanParameters = New BtScanParameters
    scanPara.ScanType = BtScanType.ActiveScanning
    If Not g.masterEmulator.IsDeviceDiscoveryOngoing Then
        g.masterEmulator.StartDeviceDiscovery(scanPara)
    End If
    g.isBusy = False
    MainForm.updateUI()
End Sub
Parents Reply
  • Seems Reset() doesn't work, I amended the program to:
    Public Sub startDeviceDiscovery() Dim scanPara As BtScanParameters = New BtScanParameters scanPara.ScanType = BtScanType.ActiveScanning
        If Not g.masterEmulator.StartDeviceDiscovery(scanPara) Then
            g.masterEmulator.Reset()
            g.isBusy = False
            MainForm.updateUI()
            Exit Sub
        End If
    End If
    g.isBusy = False
    MainForm.updateUI()
    End Sub
    But it still failed after Reset(). You can have a look on the log.txt at: www.dropbox.com/.../log.txt
