nRF51 TEMP sd_temp_get() missing codes, noise
I'm running a nRF51422QFAC and using sd_temp_get() to read the chip temperature twice / second.
I put it in a temperature chamber and swept the temperature from 0F to 100 F (18 - 38 C) slowly, over an hour. I saw some results that I can't explain.
Missing Codes
Here is a histogram of the temperature values from sd_temp_get():
image description
It looks like some codes are missing entirely from the output, even though the temperature was swept slowly over the range.
Noisy Readings
Here is the sequence of the temperature readings from sd_temp_get():
image description
There is some kind of weird noise in the readings.
Zooming in:
image description
It looks like the count dips down occasionally. These dips are always 8 or 9 counts, never less.
Is this a known behaviour?
EDIT: Added call to sd_power_mode_set((uint8_t) NRF_POWER_MODE_CONSTLAT)
Here is the histogram. The same codes are missing:
image description
Here is the timeseries. The same noise is present:
image description
And zoomed-in, the noise looked the same:
image description
