Hello , RX: nrf24LU Tx: nrf51822 use ESB Lib. But the nrf24 Can't receive data continuous.
if I Want receive 2th data , I must power up the nrf24.
This is my Code :
RFCTL = 0x10;
RFCKEN = 1;
RF = 1;
EA = 1;
hal_nrf_set_operation_mode(HAL_NRF_PRX);
hal_nrf_set_rf_channel(Test_Channal);
hal_nrf_set_output_power(HAL_NRF_0DBM);
hal_nrf_close_pipe(HAL_NRF_ALL);
hal_nrf_set_rx_payload_width((int)HAL_NRF_PIPE1, PayLoad_Length);
PayLoad_Length as receiver
hal_nrf_set_rx_payload_width((int)HAL_NRF_PIPE2, PayLoad_Length);
hal_nrf_set_rx_payload_width((int)HAL_NRF_PIPE3, PayLoad_Length);
hal_nrf_set_rx_payload_width((int)HAL_NRF_PIPE4, PayLoad_Length);
hal_nrf_set_address(HAL_NRF_TX , Rf_pipe_0_address);
transmitter
hal_nrf_set_address(HAL_NRF_PIPE1 , Rf_pipe_1_address);
hal_nrf_open_pipe(HAL_NRF_PIPE1 , true);
hal_nrf_open_pipe(HAL_NRF_PIPE2 , true);
hal_nrf_open_pipe(HAL_NRF_PIPE3 , true);
hal_nrf_open_pipe(HAL_NRF_PIPE4 , true);
hal_nrf_set_auto_retr(10,250);
hal_nrf_enable_ack_payload(false);
hal_nrf_enable_dynamic_ack(true);
hal_nrf_setup_dynamic_payload(0x1E);
hal_nrf_enable_dynamic_payload(true);
hal_nrf_set_datarate(HAL_NRF_2MBPS);
hal_nrf_set_crc_mode(HAL_NRF_CRC_16BIT);
hal_nrf_set_power_mode(HAL_NRF_PWR_UP);
CE_HIGH();
==============================THIS IS RF ISR ============================ NRF_ISR() { uint8_t irq_flags; uint8_t Loc_length;
irq_flags = hal_nrf_get_clear_irq_flags();
//hal_nrf_write_ack_payload(0,tx_payload,TX_PAYLOAD_LENGTH);
switch(irq_flags&((1<<(uint8_t)HAL_NRF_RX_DR)|
(1<<(uint8_t)HAL_NRF_TX_DS)|
(1<<(uint8_t)HAL_NRF_MAX_RT))
case (1<<(uint8_t)HAL_NRF_RX_DR):
Loc_length = hal_nrf_read_rx_payload_width();
if(Loc_length <= 32)
LED_1_On;
while(!hal_nrf_rx_fifo_empty())
hal_nrf_read_rx_payload(Glb_Rf_Desc.Payload);
Glb_Rf_Desc.Rf_Link_Lay_State.Rf_Link_Lay_State_val_Bit.Phy_Layer_updata = 1;
/** FIFO May be Flush ! **/
case (1<<(uint8_t)HAL_NRF_TX_DS):
case (1<<(uint8_t)HAL_NRF_MAX_RT):
