p_storage conflict with Device Manager
I have migrated to SDK 9.0 primarily to take advantage of some of the Advertising Mode functionality in Device Manager. While I was still in SDK 8.1, I had implemented functionality to change the Advertising Name from an IOS App. The new name was stored in pstorage and all was well. However, when I integrated the Device Manager, there are now two pstorage_init calls. I tried to combine the code from init_ p_storage with the device_manager_init, but can't seem to get the right order of things without breaking the code. When I try to combine these modules, either my Bonding/Pairing breaks or the p_storage functions don't work properly...part of the string that I try to write to flash gets written and the latter part gets jumbled. Code snippets below:
void init_p_storage(void)
	uint32_t                	retval;
	pstorage_module_param_t 	param;
	retval = pstorage_init();
	if(retval != NRF_SUCCESS)
		printf("p_storage init error\r\n");
		bsp_indication_set(BSP_INDICATE_FATAL_ERROR);
	param.block_size  = 16;                    //Select block size of 16 bytes
	param.block_count = 4;                     //Select 10 blocks, total of 160 bytes
	param.cb          = pstorage_cb_handler;   //Set the pstorage callback handler
	//printf("P_Storage initializing ... \r\n");
	// Register for pstorage
	retval = pstorage_register(&param, &pstorage_handle);
	if (retval != NRF_SUCCESS)
		printf("p_storage registration error\r\n");
	//  Get the Block Handle
	retval = pstorage_block_identifier_get(&pstorage_handle, block_num, &p_block_handle);
	APP_ERROR_CHECK(retval);
	   	printf("Error: %lu\n", retval);
static void device_manager_init(bool erase_bonds)
    dm_init_param_t        init_param = {.clear_persistent_data = erase_bonds};
    dm_application_param_t register_param;
    // Initialize peer device handle.
    err_code = dm_handle_initialize(&m_bonded_peer_handle);
    // Initialize persistent storage module.
    err_code = pstorage_init();
    err_code = dm_init(&init_param);
    memset(&register_param.sec_param, 0, sizeof(ble_gap_sec_params_t));
    register_param.sec_param.bond         = SEC_PARAM_BOND;
    register_param.sec_param.mitm         = SEC_PARAM_MITM;
    register_param.sec_param.io_caps      = SEC_PARAM_IO_CAPABILITIES;
    register_param.sec_param.oob          = SEC_PARAM_OOB;
    register_param.sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
    register_param.sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
    register_param.evt_handler            = device_manager_evt_handler;
    register_param.service_type           = DM_PROTOCOL_CNTXT_GATT_SRVR_ID;
    err_code = dm_register(&m_app_handle, &register_param);
    //app_bond_init(&m_app_bond_table);
    for(uint8_t i = 0; i < DEVICE_MANAGER_MAX_BONDS; i++)
        //APP_LOG("[APP][ID: %d], Application context : %08X\r\n",m_app_bond_table.device_id[i],(unsigned int) m_app_bond_table.app_bond_cnt[i]);
void store_DeviceName(void)
	uint32_t err_code;
	pstorage_clear(&p_block_handle, block_size);
	//printf("pstorage wait for clear to complete ... \r\n");
	while(pstorage_wait_flag) { power_manage(); }
	err_code = pstorage_store(&p_block_handle, pstorage_buffer, block_size, block_offset);
	if (err_code != NRF_SUCCESS)
    	printf("pstorage Store Error!\r\n");
// Initiate Read of Device Name from pstorage
void read_DeviceName(void)
	uint32_t err_code;
	err_code = pstorage_load(pstorage_buffer, &p_block_handle, 16, 0);
	    printf("pstorage Read Error!\r\n");
Any guidance on how to combine the init functions to have only one pstorage_init() function without breaking things would be appreciated.
Thank you.
  • Hi, pstorage_init() must only be called once before registering the first pstorage instance. Otherwise you risk getting several instances registered with the same base handle.
    Edit - Added example
    This example writes a dummy value to 0x3F800 in the "flash_write_timeout_handler". Should work together with the DM module.
    nRF51_SDK_9.0.0_ble_app_hrs_w_pstorage.zip
  • Indeed, which is why I was trying to combine the two modules into one. I am encountering the problem when trying to combine the DM initialization functions with those required for p_storage.
  • You need to remove the call to pstorage_init() in either device_manager_init() or init_p_storage() depending on which one is called first on startup.
  • yes, however, when i remove it from one or the other things break. The best question is: IS THERE AN SDK 9.0 EXAMPLE OF HOW TO USE THE DEVICE MANAGER ALONG WITH PSTORAGE. THIS IS THE PROBLEM THAT I CAN'T SEEM T OVERCOME. MY CODE WORKED IN SDK 8 WITHOUT DEVICE MANAGER.
    THANKS
  • When I follow this example (remove the pstorage_init() function from init_p_storage()) I get : p_storage registration error during pstorage init. Also the example doesn't have this function:
    which seems to be needed to read and write as below:
    Should I not be using these calls to read and write to pstorage anymore? A bit confused... Do I no longer need the storage handle?
    Thanks
1 2
