DFU SDK6.1+SD7.1 to SDK1+SD8
I'm trying to piece together how to be able to get this migration to work OTA via DFU. I was told by Nordic that all you need is to .zip SD8 + Boot(SDK10) and DFU both to update. However these seems to fail.
I followed a previous posts to create the zip using nrf.exe.
nrf.exe dfu genpkg sd8_and_boot.zip --bootloader sdk10_dfu_bootloader_xxaa.hex --softdevice s110_nrf51_8.0.0_softdevice.hex --application-version 0xffff --dev-revision 0xff --dev-type 0xff --sd-req 0xfffe
The SD update functions dfu_sd_image_swap() and dfu_sd_image_validate() don't seem to have any issues (no errors), but obviously my debugger loses track at dfu_bl_image_swap(). In bootloader_settings, it correctly tracks the sd_image_size=88344.
Inside dfu_sd_image_swap() I have the following values:
  • sd_start 4096
  • block_size 0xA800, 43008
  • img _block_start 0x2B000, 176128
  • sd_block_start 0x16000
  • image_end 0x2B918, 178456
Inside dfu_sd_image_validate() I have the following setting values:
  • sd_image_size 0x15918 88344 (correct for SD 8)
  • sd_image_start 0x16000
I also noted that dfu_image_validate() fails because the m_image_crc != received_crc. However the entry in m_init_packet[3] does contain the correct CRC value. Is this a compatibility issue?
Is there anything I'm missing to be able to support this OTA migration?
Thanks for the help guys,
  • The update procedure in SDK 6.1.0 differs slightly from the bootlaoder in SDK 7 and later. Mainly that the extended init packet is not supported which causes the wrong crc value to be parsed from the init packet. So to update from this bootloader you will need to use a different distribution packet so nrftoolbox goes into "legacy" mode
    Steps to create legacy distribution packet for Android (nrftoolbox v. 1.16.3):
    Create a .zip folder with bootloader.hex and softdevice.hex.
    Example : sd8sdk10_android.zip
    Same for iOS (nrftoolbox v.3.0.1):
    Use nrf.exe as you described, but edit the manifest and .dat (CRC = last 2 bytes) file so the init packet only contains the CRC value.
    Eg., manifest.json:
        "manifest": {
            "dfu_version": 0.5,
            "softdevice_bootloader": {
                "bin_file": "sd_bl.bin",
                "bl_size": 13172,
                "dat_file": "sd_bl.dat",
                "init_packet_data": {
                     "firmware_crc16": 32149,
                "sd_size": 88344
    Example : sd8sdk10_ios2.zip
    Also, you will need to do a minor change in the SDK 10.0.0 bootloader to keep the same bootloader settings format as SDK 6.1.0 in flash. The bootloader_settings_t is the same for both examples, but the size of the enum is not. This will affect the location of the struct members, and cause the new bootloader to read out the wrong values from the bootlaoder settings page in flash.
    In the old version we had set the "enum as int compiler" option:
    image description
    This option is disabled in the newer SDKs, and instead of enabling it again I added the BANK_UNUSED member.
    typedef enum
        BANK_VALID_APP   = 0x01,
        BANK_VALID_SD    = 0xA5,
        BANK_VALID_BOOT  = 0xAA,
        BANK_ERASED      = 0xFE,
        BANK_INVALID_APP = 0xFF,
        BANK_UNUSED      = 0xFFFFFFF,
    } bootloader_bank_code_t;
    This is a somewhat hacky way of making all the members in this enum to have the size of an 'int' to avoid affecting other enums that may be used in your project. Have only tested this with Keil.
    Update - the bootloader settings problem when doing DFU of BL from SDK 6.1.0 to SDK 10.0.0
    A known problem with doing bootloader update from SDK 6.1.0 to one from SDK 7.x.x or later is that bootloader settings structure is stored differently in flash because of the "enum contrainer always int" option that was used before.
    The picture below shows how the "enum contrainer always int" option affects the format of how the structure is stored to flash.The first line shows the result with the option enabled during SD+BL update, and the second line shows the same without it enabled (default SDK 7+). Notice the offset on every struct member after bank_0 when comparing these two.
    image description
    So the problem is that the new bootloader (sdk 10.0.0) will read the wrong values from flash in the bootloader_dfu_sd_update_continue() function, hence failing to reach bootloader_dfu_sd_update_finalize() to complete the update.
    When I tried this with Keil it was sufficient to add BANK_UNUSED = 0xFFFFFFF to get the same format between SDK 10.0.0 and SDK 6.1.0. as I mentioned earlier. Please make sure that you do have the same format for your bootloaders so we know that this is not why it is failing at your end.
  • HI Vidar,
    I added the BANK_UNUSED = 0xFFFFFFF to my bootloader settings on the SDK10 bootloader image. However the upload is still not successful/
    The settings in my previous response are the settings stored i flash. I obtain them via a Flash readback after the DFU.
