Connection param update delay
I'm running into a weird problem where there is a long delay that is variable between calling ble_conn_params_change_conn_params() and receiving the BLE_GAP_EVT_CONN_PARAM_UPDATE event.
I have the following connection params:
#define MIN_CONN_INTERVAL_IDLE          MSEC_TO_UNITS(500, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL_IDLE          MSEC_TO_UNITS(1000, UNIT_1_25_MS)
#define MIN_CONN_INTERVAL_CAL           MSEC_TO_UNITS(250, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL_CAL           MSEC_TO_UNITS(500, UNIT_1_25_MS)
#define SLAVE_LATENCY                   0
#define CONN_SUP_TIMEOUT_IDLE           MSEC_TO_UNITS(4000, UNIT_10_MS)
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(1000, APP_TIMER_PRESCALER)
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER)
#define MAX_CONN_PARAMS_UPDATE_COUNT    3
I'm using an iOS device as a central and according to Apple's Bluetooth Design Guidelines (developer.apple.com/.../BluetoothDesignGuidelines.pdf) my connection params are valid.
Here's the log of one run:
[11:11:35:263] Start advertisement
[11:12:01:449] Connected
[11:12:01:702] Auth correct
[11:12:02:840] Conn param update: 798, 798
[11:12:02:840] BLE_CONN_PARAMS_EVT_SUCCEEDED
[11:13:16:142] Update connection parameters: CAL
[11:13:30:110] Conn param update: 399, 399
[11:13:30:110] BLE_CONN_PARAMS_EVT_SUCCEEDED
[11:14:07:305] Update connection parameters: IDLE
[11:14:14:282] Conn param update: 798, 798
[11:14:14:282] BLE_CONN_PARAMS_EVT_SUCCEEDED
So the first param update occurred about 1 sec after the connect event so that is correct. But there is 14 sec delay for the 2nd conn param update and a 7 sec delay for the 3rd.
Here's another run:
[11:15:27:190] Start advertisement
[11:15:55:492] Connected
[11:15:55:765] Auth correct
[11:15:56:902] Conn param update: 798, 798
[11:15:56:902] BLE_CONN_PARAMS_EVT_SUCCEEDED
[11:16:56:885] Update connection parameters: CAL
[11:17:17:840] Conn param update: 399, 399
[11:17:17:840] BLE_CONN_PARAMS_EVT_SUCCEEDED
[11:17:49:951] Update connection parameters: IDLE
[11:17:58:926] Conn param update: 798, 798
[11:17:58:926] BLE_CONN_PARAMS_EVT_SUCCEEDED
Once again the first param update is correct but now the delay for the 2nd update is 21 sec and 9 sec for the 3rd update.
What is going on here? Why are the delays so long and different between updates? Is this something that iOS does which is not documented? Or am I missing something here?
Thanks for your help.
