nRF52832 DCDC problem
I'm trying out the nRF52832 with kit PCA10040 V 0.9.0. I have S132 softdevice installed and running the ble_app_pwr_profiling example from nRF5 SDK v11.0.0.
I'm trying to enable the dcdc to reduce current consumption when transmitting with the radio. When i add the line "sd_power_dcdc_mode_set(1)", the advertising do not work.
Here is the main.c. I only added "sd_power_dcdc_mode_set(1)" on line 676.
Any ideas ?
main.c
EDIT: It works if i remove the call "power_manage();" (line 710). Why ?
EDIT: I have the rev B. I see in the rev B errata document that the DC/DC does not automatically switch off in system ON IDLE. Is there a way to switch it off between advertising events?
EDIT: I have tried replacing the line "power_manage();" by the following code to enable and disable the DC/DC manually when the radio is on or off:
do{
   __WFE();
}while (!NRF_RADIO->POWER);
NRF_POWER->DCDCEN = 1;
NRF_TIMER0->TASKS_START = 1;
NRF_TIMER0->TASKS_STOP = 1;
do{
   __WFE();
}while (NRF_RADIO->POWER);
NRF_TIMER0->TASKS_SHUTDOWN = 1;
NRF_POWER->DCDCEN = 0;
(void)sd_power_mode_set((nrf_power_mode_t) 1);
Unfortunately the advertising will not work with the code above. What could be the problem?
