BDS fails to genrate working code for the BLE Cycling Power Service
Does anyone have a working copy of ble_cps.c\h
The BDS (version 1.0.2095.0) plugin (v.1.2.4) does not generate code that compiles under IAR EWB
IAR ANSI C/C++ Compiler V7.40.2.8542/W32 for ARM Copyright 1999-2015 IAR Systems AB. Error[Pe549]: variable "flags" is used before its value is set C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 31 Error[Pe020]: identifier "C1_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 62 Error[Pe020]: identifier "C1_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 66 Error[Pe020]: identifier "C2_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 70 Error[Pe020]: identifier "C2_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 74 Error[Pe020]: identifier "C3_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 78 Error[Pe020]: identifier "C3_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 82 Error[Pe020]: identifier "C4_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 86 Error[Pe020]: identifier "C4_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 90 Error[Pe020]: identifier "C5_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 94 Error[Pe020]: identifier "C5_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 98 Error[Pe549]: variable "properties" is used before its value is set C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 118 Error[Pe549]: variable "cycling_power_feature" is used before its value is set C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 180 Error[Pe549]: variable "flags" is used before its value is set C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 256 Error[Pe020]: identifier "C1_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 276 Error[Pe020]: identifier "C1_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 280 Error[Pe020]: identifier "C2_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 285 Error[Pe020]: identifier "C2_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 289 Error[Pe020]: identifier "C1_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 338 Error[Pe020]: identifier "C1_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 342 Error[Pe020]: identifier "C2_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 346 Error[Pe020]: identifier "C1_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 396 Error[Pe020]: identifier "C1_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 400 Error[Pe020]: identifier "C2_required" is undefined C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 404 Error[Pe177]: function "server_characteristic_configuration_encode" was declared but never referenced C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 131 Error[Pe177]: function "server_characteristic_configuration_decode" was declared but never referenced C:\SVN_3\Software\BLE cycling_power_sensor\trunk\ble_cps.c 163
  • Can you please try with the plugin attached by David Edwin here and let me know if it helps.
    Also not sure if the plugin works out of the box with IAR, can you check your code works with KEIL?
  • The plugin you refer to is the one I used.
    Unfortunately I do not have access to Keil tools.
  • I the plugin is in beta phase and I think has been tested only in keil IMHO
  • I have the same problem. I work with Keil v5 and BDS 1.1 and the above mentioned plugin. still the code cant be generated due to similar problems:
    *** Using Compiler 'V5.06 update 3 (build 300)', folder: 'D:\Program Files\Keil_v5\ARM\ARMCC\Bin' Rebuild target 'nrf52832_xxaa_s132' compiling ble_cps.c... ......\ble_cps.c(62): error: #20: identifier "C1_required" is undefined if (C1_required) ......\ble_cps.c(66): error: #20: identifier "C1_required" is undefined if (C1_required) ......\ble_cps.c(70): error: #20: identifier "C2_required" is undefined if (C2_required) ......\ble_cps.c(74): error: #20: identifier "C2_required" is undefined if (C2_required) ......\ble_cps.c(78): error: #20: identifier "C3_required" is undefined if (C3_required) ......\ble_cps.c(82): error: #20: identifier "C3_required" is undefined if (C3_required) ......\ble_cps.c(86): error: #20: identifier "C4_required" is undefined if (C4_required) ......\ble_cps.c(90): error: #20: identifier "C4_required" is undefined if (C4_required) ......\ble_cps.c(94): error: #20: identifier "C5_required" is undefined if (C5_required) ......\ble_cps.c(98): error: #20: identifier "C5_required" is undefined if (C5_required) ......\ble_cps.c(278): error: #20: identifier "C1_required" is undefined if (C1_required) ......\ble_cps.c(282): error: #20: identifier "C1_required" is undefined if (C1_required) ......\ble_cps.c(287): error: #20: identifier "C2_required" is undefined if (C2_required) ......\ble_cps.c(291): error: #20: identifier "C2_required" is undefined if (C2_required) ......\ble_cps.c(340): error: #20: identifier "C1_required" is undefined if (C1_required) ......\ble_cps.c(344): error: #20: identifier "C1_required" is undefined if (C1_required) ......\ble_cps.c(348): error: #20: identifier "C2_required" is undefined if (C2_required) ......\ble_cps.c(398): error: #20: identifier "C1_required" is undefined if (C1_required) ......\ble_cps.c(402): error: #20: identifier "C1_required" is undefined if (C1_required) ......\ble_cps.c(406): error: #20: identifier "C2_required" is undefined if (C2_required) ......\ble_cps.c(131): warning: #177-D: function "server_characteristic_configuration_encode" was declared but never referenced static uint8_t server_characteristic_configuration_encode(ble_cps_server_characteristic_configuration_t * p_server_characteristic_configuration, uint8_t * encoded_buffer) ......\ble_cps.c(163): warning: #177-D: function "server_characteristic_configuration_decode" was declared but never referenced static uint8_t server_characteristic_configuration_decode(uint8_t data_len, uint8_t * p_data, ble_cps_server_characteristic_configuration_t * p_write_val) ......\ble_cps.c: 2 warnings, 20 errors compiling service_if.c... compiling main.c... compiling bsp.c... compiling bsp_btn_ble.c... compiling ble_advdata.c... compiling ble_advertising.c... compiling ble_conn_params.c... compiling ble_srv_common.c... compiling app_uart.c... compiling nrf_delay.c... compiling device_manager_peripheral.c... compiling nrf_drv_common.c... compiling nrf_drv_gpiote.c... compiling nrf_drv_uart.c... compiling pstorage.c... compiling app_button.c... compiling app_error.c... compiling app_trace.c... compiling app_error_weak.c... compiling app_timer.c... compiling app_util_platform.c... compiling fstorage.c... compiling nrf_assert.c... compiling RTT_Syscalls_KEIL.c... compiling SEGGER_RTT.c... compiling SEGGER_RTT_printf.c... compiling nrf_log.c... assembling arm_startup_nrf52.s... compiling retarget.c... compiling softdevice_handler.c... compiling system_nrf52.c... "._build\nrf52832_xxaa_s132.axf" - 20 Error(s), 2 Warning(s). Target not created. Build Time Elapsed: 00:00:55
