Set OOB key on Master Control Panel?
Is there a way to set the OOB key while using the master control panel windows software?
Edit: and if not, is there a quick method to test a peripheral's OOB implementation? (assuming I know the OOB key) from a PC or Mac or Ubuntu or some other target??
best regards,
Matthew
  • [ EDIT ] : OOB is now supported with MCP v3.10. Go to File -> Option -> Security, you can enable Out of Band authentication support.
    Original post:
    There isn't any way to do OOB with the Master Control Panel itself, but if you want to, you should be able to test this by making a custom application based on the Master Emulator API. This API is available in C:\Program Files (x86)\Nordic Semiconductor\Master Emulator\2.1.7.8226\ when having installed the Master Control Panel.
    Original post:
