How do I reject an write to a character if the value is out of range?
I'm modifying the LED button example to fit my custom characteristic.
How could I modify the functionns to reject a value if the value is not in range?
I have the following functione that get called in secuence when the LED characteristic is written. Where can I reject the value if it is not 0 or 1?
static void on_write(ble_lbs_t * p_lbs, ble_evt_t * p_ble_evt)
    ble_gatts_evt_write_t * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
    if ((p_evt_write->handle == p_lbs->led_char_handles.value_handle) &&
        (p_evt_write->len == 1) &&
        (p_lbs->led_write_handler != NULL))
        p_lbs->led_write_handler(p_lbs, p_evt_write->data[0]);
static void led_write_handler(ble_lbs_t * p_lbs, uint8_t led_state)
    if (led_state == 1)
        LEDS_ON(LEDBUTTON_LED_PIN);
    else if(led_state == 0)
        LEDS_OFF(LEDBUTTON_LED_PIN);
    else reject????()  <-- Could I insert some sort of reject function here? How do I do it?
