I'm connecting to a proximity sensor, IQS263 over TWI interface and having some weird problems.
I'm using the same code I used to connect with the Invensense MPU 9250 so I know that on the same platform, the same code works fine with no problems.
For the IQS263 part I need to pull a RDY line high (which I do via GPIO).
Then I just init the TWI in the standard manner and start trying to talk to the device.
It just seems to hang and tracing down through nrf_drv_twi.c it seems this never happens
if (nrf_twi_event_check(p_twi, NRF_TWI_EVENT_TXDSENT))
if I look in function twi_x_start_transfer basically that it gets stuck here
while (twi_transfer(p_twi, &p_cb->error, &p_cb->bytes_transferred, (uint8_t *)p_data, length, no_stop))
Note the first bit of code here is down in twi_transfer and appears to just never get a TXD sent...
I'm working remotely at the moment so I can't scope the part/TWI bus to check what's happening so it could likely be a HW issue as I said the TWI code runs on another board for a different device..
My configuration is like this
static uint32_t twi_master_init(void)
uint32_t err_code;
const nrf_drv_twi_config_t config =
.scl = PROXIMITY_I2C_SCL,
.sda = PROXIMITY_I2C_SDA,
.frequency = TWI0_CONFIG_FREQUENCY,
.interrupt_priority = TWI0_CONFIG_IRQ_PRIORITY
err_code = nrf_drv_twi_init(&m_twi_master, &config, NULL /*twi_handler*/, NULL);
nrf_drv_twi_enable(&m_twi_master);
RMLOG("I2C sensor is at address 0x%02X SCL is %u and SDA is %u",
IQS263_ADDR,
PROXIMITY_I2C_SCL,
PROXIMITY_I2C_SDA);
And sending looks like this...
static int i2c_read(unsigned char slave_addr, unsigned char reg_addr, unsigned char length, unsigned char *data)
uint32_t err_code=0;
if (!twi_inited) {
return -1;
// We need to pull the RDY line low
nrf_gpio_cfg_output(PROXIMITY_I2C_RDY);
nrf_gpio_pin_clear(PROXIMITY_I2C_RDY);
RMLOG("R[0x%02X]: A: 0x%02X L: %u", slave_addr, reg_addr, length);
// Write the register we want to read
err_code = nrf_drv_twi_tx(&m_twi_master, slave_addr, ®_addr, 1, true);
if (err_code != NRF_SUCCESS) {
RMLOG("Failed to write register to read");
return -1;
RMLOG("Going to read it");
// Read it
err_code = nrf_drv_twi_rx(&m_twi_master, slave_addr, data, length);
RMLOG("Failed to read register");
else {
RMLOG("First byte of response was 0x%02X", *data);
// Let it float high.. well, it should have a pull up high actually...
nrf_gpio_pin_set(PROXIMITY_I2C_RDY);
RMLOG("Finished");
return 0;
Any help appreciated if someone has an idea off the top of their head...
