I modified the code from the tutorial at devzone.nordicsemi.com/.../ to send measurements from my RHT sensor but encountered some basic difficulties. After fitting the example code from github to my requirements, I tried flashing it with the default memory ranges set in Keil project, but it is generating hardfault error (of course I do it after flashing s130 softdevice). After modifying the ranges the same way as in SoftDevice Specification for my softdevice version (S130_SDS_v2.0), my program flashed properly and doesn't generate hardfault while running but still don't react in any way. So I tried running the example code from github (CompletedCode from BLE characteristics tutorial from Nordic) without any changes (only filling it with the memory ranges from SDS), but it still doesn't give me any reaction as I expect. Changing a number of LED in nrf_gpio_pin_toggle() in timer_timeout_handler() causes no reaction, it still blinks the same LED_0 (number of pins with LEDs are set properly). MCU without flashing softdevice and any BLE utilisation works fine (the program providing the communication via I2C with RHT sensor runs without any problems). I'll be very thankful for any advice what I should do next to run this example.
I'm using:
nRF5_SDK_11.0.0,
BLE 400 with NRF51822 board
