Why can't I add more that 4 input signals?
I have12 input pins to my application. But the code fails when I try to add the fifth button.
Is there a limit to how many input signals I can add?
static void gpio_inputs_init(void)
	uint32_t err_code;
	if (!nrf_drv_gpiote_is_init())
	setup_button(PIN_BUTTON_0);
	setup_button(PIN_BUTTON_1);
	setup_button(PIN_BUTTON_2);
	setup_button(PIN_BUTTON_3);
	setup_button(PIN_BUTTON_4);
	setup_button(PIN_BUTTON_5);
	setup_button(PIN_BUTTON_6);
	setup_button(PIN_BUTTON_7);
	setup_button(PIN_BUTTON_8);
	setup_button(PIN_BUTTON_9);
	setup_button(PIN_BUTTON_CLEAR);
	setup_button(PIN_BUTTON_OK);
static void setup_button(nrf_drv_gpiote_pin_t pin)
	uint32_t err_code;
	nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(false);
	in_config.pull = NRF_GPIO_PIN_PULLUP;
	err_code = nrf_drv_gpiote_in_init(pin, &in_config,
			in_pin_event_handler);
	nrf_drv_gpiote_in_event_enable(pin, true);
I have single stepped my code and it is channel_port_alloc() that is called by nrf_drv_gpiote_in_init() that returns NO_CHANNELS:
ret_code_t nrf_drv_gpiote_in_init(nrf_drv_gpiote_pin_t pin,
                                  nrf_drv_gpiote_in_config_t const * p_config,
                                  nrf_drv_gpiote_evt_handler_t evt_handler)
    ASSERT(pin < NUMBER_OF_PINS);
    ret_code_t result = NRF_SUCCESS;
    /* Only one GPIOTE channel can be assigned to one physical pin. */
    if (pin_in_use_by_gpiote(pin))
        result = NRF_ERROR_INVALID_STATE;
        int8_t channel = channel_port_alloc(pin, evt_handler, p_config->hi_accuracy);  <---- **** This function gives the error ****
        if (channel != NO_CHANNELS)
            if (p_config->is_watcher)
                nrf_gpio_cfg_watcher(pin);
                nrf_gpio_cfg_input(pin,p_config->pull);
            if (p_config->hi_accuracy)
                nrf_gpiote_event_configure(channel, pin,p_config->sense);
                m_cb.port_handlers_pins[channel-NUMBER_OF_GPIO_TE] |= (p_config->sense)<< SENSE_FIELD_POS;
            result = NRF_ERROR_NO_MEM;
    return result;
