Hard Fault on SD functions not in main
i have a problem with the PCA10040. I try to set up a ANT Transmit Channel.
If "ant_channel_init" is called from main everything works fine.
But if it's called from other c file the Softdevice call "sd_ant_channel_assign" end in hardfault. Also other Softdevice calls from this C File end in HardFault. But from Main.c they work.
I've tried with a higher Stack Size which doesn't change the problem.
Any suggestions?
Greets, Andi
