peer manager and iPhone encryption key
I'm testing pairing and bonding with an iPhone running iOS 9.3.1 and nRF52832. I'm running into trouble when reconnecting to a previously paired device.
The first time I pair and enable encryption, everything works perfectly. The next time I connect to the iPhone, peer manager immediately gives me a PM_EVT_CONN_SEC_FAILED event every time with reason PM_CONN_SEC_ERROR_PIN_OR_KEY_MISSING.
calling pm_conn_secure(periph_conn.periph_conn_hand, true); has no effect as well as pm_conn_secure(periph_conn.periph_conn_hand, false);
either one will return NRF_SUCCESS but the link never re-pairs or encrypts. This is is serious problem for ANCS since the application is blocked from that service over an unencrypted link.
The only way to get the link to encrypt is to forget the device in the bluetooth settings and then reconnect to it. But again, this only works once. So even though the iphone will always auto-connect to the device, the peer manager always sends the PM_EVT_CONN_SEC_FAILED event.
my security parameters are as follows:
sec_param.bond           = 1;
sec_param.mitm           = 0;
sec_param.io_caps        = BLE_GAP_IO_CAPS_NONE;
sec_param.oob            = 0;
sec_param.min_key_size   = 7;
sec_param.max_key_size   = 16;
sec_param.kdist_own.enc  = 1;
sec_param.kdist_own.id   = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id  = 1;
I have not seen this behavior on Android 5+.
This project is built with
S132 v2.0.0
nRF52832
nRF5 SDK v11.0.0
Release date: Week 10, 2016
Eclipse Mars GCC 5 2016q1
  • It looks like everything is OK. Sometimes "Just works" pairing can be unreliable with the iPhone. This was causing my application to attempt different measures to ensure pairing that would ultimately cause the stored keys to be deleted.
    I have since switched to MITM pairing with display only IO. Using the pass code provided by iOS has proven to be vastly more reliable when pairing. It also seems that reconnecting is not showing the erratic behavior it was showing before.
