May need to set the device into BLE mode first?
If you modify the bootloader to work with the S310, and make sure to upload a binary that is compiled for the S310, this should be perfectly possible.
You can refer to the attached document for information on what needs to change to make the bootloader work with S310.
Thank you. Ole! I will try it out.
No problem, but I'd be happy if you could accept the answer instead of posting a thank-you-reply! :)
