Problem with simultaneous transmission and reception
Hi all again guys! I am experiencing a problem with my application: i have a beacon that is sending ADC converted values to a nrf51 DK (via notification), which is connected to the pc to receive these values via USB and visualize them; from the pc, i also send back some values at precise moments to the beacon, via write without response, so that the transmission is bi-directional. What happens is that sometimes (it seems pretty much random, other times it all goes good with no problems), when i decide to send some numbers from the PC using the write operation (while of course i am still receiving notifications simultaneously), this causes a disconnection between the two devices (i think probably because of an error occurring in these operations), with consequent loss of data sent by notification, that should be continuous and real-time. What could be the problem? Isn't the nrf51 capable of handling both transmission and reception simultaneously? Please note that my connection parameters between the two devices are 10 ms of connection interval, and 0 slave latency.
Thanks in advance and tell me if any other information are needed!
projects.rar
  • I know this, i found it strange too but consider this: app_error_handler is called ONLY just before the reset (so it must be the cause), and exactly when i send something to the beacon and it puts it out with uart. So, the error code inside app_error_handler, that is the NO MEM stuff, can only come from the uart function. After this, unfortunately i don't have the tools to get out from the beacon the value of the line number, because my only possibility is to turn on the LED to verify if the error code is what i supposed (like i do with no mem)... can you do this for me or tell me a way to get this value?
