I have written a custom characteristic and now I want to preserve its value in flash.
Is there any example of how to do this?
You can use pstorage library, it is well described here
It would be so much easier and faster if there was an example. I can't get it to work.
I finally got it to work. But could someone at Nordic comment on this code if I do something wrong (even while it works).
This is my test code:
static pstorage_handle_t pstorage_handle;
static uint8_t pstorage_wait_flag = 0;
static pstorage_block_t pstorage_wait_handle = 0;
// Event Notification Handler.
static void example_cb_handler( pstorage_handle_t * handle, uint8_t op_code, uint32_t result, uint8_t * p_data, uint32_t data_len )
SEGGER_RTT_printf( 0, "op_code = %" PRIu8 ", result = %" PRIu32 ", data_len = %" PRIu32 ", data = ", op_code, result, data_len );
for ( uint32_t i = 0; i < data_len; i++ )
SEGGER_RTT_printf( 0, "%" PRIu8 " ", p_data[ i ] );
SEGGER_RTT_printf( 0, "\n" );
if ( handle->block_id == pstorage_wait_handle )
switch ( op_code )
case PSTORAGE_STORE_OP_CODE:
case PSTORAGE_LOAD_OP_CODE:
case PSTORAGE_CLEAR_OP_CODE:
case PSTORAGE_UPDATE_OP_CODE:
void test( void )
uint32_t err_code;
pstorage_handle_t block_0_handle;
uint8_t block_0_write_data[ 32 ] =
{ 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31 };
uint8_t block_0_read_data[ 32 ];
// Initialize persistent storage module.
err_code = pstorage_init();
APP_ERROR_CHECK( err_code );
pstorage_module_param_t param =
{ .block_size = 32, .block_count = 1, .cb = example_cb_handler };
SEGGER_RTT_printf( 0, "\r\n\r\npstorage initializing ... \r\n" );
err_code = pstorage_register( ¶m, &pstorage_handle );
pstorage_block_identifier_get( &pstorage_handle, 0, &block_0_handle );
pstorage_wait_handle = block_0_handle.block_id;
pstorage_wait_flag = 1;
err_code = pstorage_clear( &block_0_handle, 32 );
while ( pstorage_wait_flag )
power_manage(); //Sleep until store operation is finished.
pstorage_wait_handle = block_0_handle.block_id; //Specify which pstorage handle to wait for
pstorage_wait_flag = 1; //Set the wait flag. Cleared in the example_cb_handler
SEGGER_RTT_printf( 0, "pstorage store into block 0\r\n" );
err_code = pstorage_store( &block_0_handle, block_0_write_data, 32, 0 ); //Write to flash
SEGGER_RTT_printf( 0, "pstorage wait for block 2 store to complete ... \r\n" );
SEGGER_RTT_printf( 0, "pstorage load blocks 0 \r\n" );
err_code = pstorage_load( block_0_read_data, &block_0_handle, 32, 0 );
SEGGER_RTT_printf( 0, "dest_data_0 = " );
for ( uint32_t i = 0; i < 32; i++ )
SEGGER_RTT_printf( 0, "%" PRIu8 " ", block_0_read_data[ i ] );
And the RTT viewer output:
0> pstorage initializing ...
0> sys_evt_dispatch()
0> op_code = 3, result = 0 data_len = 32 data = 192 7 0 0 209 6 0 0 209 0 0 0 177 6 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0> pstorage store into block 0
0> pstorage wait for block 2 store to complete ...
0> op_code = 1, result = 0 data_len = 32 data = 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
0> pstorage load blocks 0
0> op_code = 2, result = 0 data_len = 32 data = 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
0> dest_data_0 = 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
