uart configuration putty?
I am new to MCUs and I am trying to send information from NRF51 via UART (not BLE UART) to Putty. No matter what I try I can't seem to print anything on Putty. I started working with the template file under peripherals. The file produces no errors on keil.
I am using NRF_LOG_PRINTF statement. Here is the code:
    /* Copyright (c) 2009 Nordic Semiconductor. All Rights Reserved.
 * The information contained herein is property of Nordic Semiconductor ASA.
 * Terms and conditions of usage are described in detail in NORDIC
 * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
 * Licensees are granted free, non-transferable use of the information. NO
 * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
 * the file.
/** @file
* @brief Example template project.
* @defgroup nrf_templates_example Example Template
#include "RTE_Components.h"             // Component selection
#include <stdbool.h>
#include <stdint.h>
#include "nrf_adc.h"
#include "nrf.h"
#include "nrf_gpio.h"
#include "nordic_common.h"
#include "nrf_delay.h"
#include "app_error.h"
#include "app_timer.h"
#include "boards.h"
#include "bsp.h"
#include "nrf_drv_adc.h"
#include "nrf_drv_config.h"
#include "nrf_log.h"
#include "nrf_drv_uart.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
//Main function
	uint32_t err_code;
	err_code = NRF_LOG_INIT();
	if (err_code != NRF_SUCCESS)
			// Module initialization failed. Take corrective action.
	NRF_LOG_PRINTF("Hello World \n");
  • you have to add a define in the preprocessor symbols.
    Add ENABLE_DEBUG_LOG_SUPPORT to Menu/project/options for target /c/c++/preprocessor symbols
    See app_trace.h
    Edit:
    preprocessor symbols are a basic programming construct, a little out of scope for this forum. Do a code search for ENABLE_DEBUG_LOG_SUPPORT and see what it does.
    BTW, You shouldn't need to init the uart manually
  • Ok, I tried that it did not work. This is what I have for preprocessor symbols now: BOARD_PCA10028 NRF51 SWI_DISABLE0 NRF51 ENABLE_DEBUG_LOG_SUPPORT
  • Also what exactly are preprocessor symbols and how do they impact coding the NRF51?
  • preprocessor symbols, are flags that are used when compiling the software to make some decisions, and some code is compiled or not because of the Symbols you select.
    This is the only thing you have on your main? which nRF are you using? You can try to initialize the UART like
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
        const app_uart_comm_params_t comm_params =
            RX_PIN_NUMBER,
            TX_PIN_NUMBER,
            RTS_PIN_NUMBER,
            CTS_PIN_NUMBER,
            APP_UART_FLOW_CONTROL_ENABLED,
            false,
            UART_BAUDRATE_BAUDRATE_Baud115200
    APP_UART_FIFO_INIT( &comm_params,
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOW,
                       err_code);
    then you should use printf to print what you want. Pay attention to the pins you configure and the Baudrate, because they need to match with your chip and your selected baudrate on Putty.
  • What type of UART is on the device where you are running Putty? Is it a "normal" RS-232 serial port or something else?
    The GPIO pins on the nRF51 will want/use 0 volts for a zero bit and something around +3 volts for a one bit.
    On the other hand, an RS-232 port -- like you would commonly find on a computer -- uses a voltage of less than -3 volts for a zero and more than +3 volts for a one. Common RS-232 voltages are +/-12 volts.
    So, if you are trying to connect a "normal" serial port to the UART on your nRF51 it wont work.
    If this is your problem you'll need a level shifter to match the voltages. Or, you could get a USB serial adapter that uses 0/+3. The adapter appears to your computer as a regular serial port but the electronics end that connects to your nRF51 is at 0/3 volts. (Actually they are usually 0/+3.3 volts but that's close enough to +3 to make it work.)
    This type of adapter can be found online at pretty much every electronics parts store for $10 to $20. I've been getting them at Sparkfun, but I'm pretty sure you can get them at Digi-Key, SeeedStudio, or sites where you can buy accessories for Arduinios or Raspberry PIs.
    --- ta2
