sd_ble_gap_adv_stop() never returns - HardFault
Hello - I've got an application which won't return from adv_stop(). If I hit stop on the debugger we are inside the hard fault handler. Any clues as to what to check?
In my advertising event handler I see:
  • BLE_ADV_EVT_WHITELIST_REQUEST
  • BLE_ADV_EVT_FAST
This is SDK 10.0.0, NRF51822.
    uint32_t err_code;
    timers_init();
    // Initialize SoftDevice.
    ble_stack_init();
    gap_params_init();
    device_manager_init(false); // required for advertising module
    service_add();
    advertising_module_init();
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST); // using new module
    err_code = sd_ble_gap_adv_stop();  // goes to hard fault handler.
  • I am not able to reproduce it. Do you have code that can run on the DK and will produce the error?
    Also, I found this similar case, but it was not solved.
  • I've the same error with the beacon example S140, here the main.c, I have added a function Stop that only is called once and when it happens goes to hard_fault
     * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_beacon_main main.c
     * @ingroup ble_sdk_app_beacon
     * @brief Beacon Transmitter Sample Application main file.
     * This file contains the source code for an Beacon transmitter sample application.
    #include <stdbool.h>
    #include <stdint.h>
    #include "nordic_common.h"
    #include "bsp.h"
    #include "nrf_soc.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "ble_advdata.h"
    #include "app_timer.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                  /**< A tag identifying the SoftDevice BLE configuration. */
    #define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_0_625_MS)  /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
    #define APP_BEACON_INFO_LENGTH          0x17                               /**< Total length of information advertised by the Beacon. */
    #define APP_ADV_DATA_LENGTH             0x15                               /**< Length of manufacturer specific data in the advertisement. */
    #define APP_DEVICE_TYPE                 0x02                               /**< 0x02 refers to Beacon. */
    #define APP_MEASURED_RSSI               0xC3                               /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
    #define APP_COMPANY_IDENTIFIER          0x0059                             /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
    #define APP_MAJOR_VALUE                 0x01, 0x02                         /**< Major value used to identify Beacons. */
    #define APP_MINOR_VALUE                 0x03, 0x04                         /**< Minor value used to identify Beacons. */
    #define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                            0x45, 0x56, 0x67, 0x78, \
                                            0x89, 0x9a, 0xab, 0xbc, \
                                            0xcd, 0xde, 0xef, 0xf0            /**< Proprietary UUID for Beacon. */
    #define DEAD_BEEF                       0xDEADBEEF                         /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
    #define MAJ_VAL_OFFSET_IN_BEACON_INFO   18                                 /**< Position of the MSB of the Major Value in m_beacon_info array. */
    #define UICR_ADDRESS                    0x10001080                         /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
    static ble_gap_adv_params_t m_adv_params;                                  /**< Parameters to be passed to the stack when starting advertising. */
    static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
    static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];  /**< Buffer for storing an encoded advertising set. */
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = NULL,
            .len    = 0
    static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
        APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                             // implementation.
        APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                             // manufacturer specific data in this implementation.
        APP_BEACON_UUID,     // 128 bit UUID value.
        APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
        APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
        APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                             // this implementation.
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in]   line_num   Line number of the failing ASSERT call.
     * @param[in]   file_name  File name of the failing ASSERT call.
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        uint32_t      err_code;
        ble_advdata_t advdata;
        uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
        ble_advdata_manuf_data_t manuf_specific_data;
        manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
        // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
        // UICR instead of using the default values. The major and minor values obtained from the UICR
        // are encoded into advertising data in big endian order (MSB First).
        // To set the UICR used by this example to a desired value, write to the address 0x10001080
        // using the nrfjprog tool. The command to be used is as follows.
        // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
        // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
        // the following command should be used.
        // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
        uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
        uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
        uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
        m_beacon_info[index++] = MSB_16(major_value);
        m_beacon_info[index++] = LSB_16(major_value);
        m_beacon_info[index++] = MSB_16(minor_value);
        m_beacon_info[index++] = LSB_16(minor_value);
        manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
        manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type             = BLE_ADVDATA_NO_NAME;
        advdata.flags                 = flags;
        advdata.p_manuf_specific_data = &manuf_specific_data;
        // Initialize advertising parameters (used when starting advertising).
        memset(&m_adv_params, 0, sizeof(m_adv_params));
        m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
        m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
        m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
        m_adv_params.duration        = 0;       // Never time out.
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
        ret_code_t err_code;
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for initializing logging. */
    static void log_init(void)
    /**@brief Function for initializing LEDs. */
    static void leds_init(void)
        ret_code_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
    /**@brief Function for initializing timers. */
    static void timers_init(void)
            nrf_pwr_mgmt_run();
    void Stop()
     sd_ble_gap_adv_stop(m_adv_handle);
     * @brief Function for application main entry.
        uint8_t i = 0;
        // Initialize.
        log_init();
        timers_init();
        leds_init();
        power_management_init();
        ble_stack_init();
        advertising_init();
        // Start execution.
        NRF_LOG_INFO("Beacon example started.");
        advertising_start();
        // Enter main loop.
        for (;; )
            idle_state_handle();
            if(i == 0)
              i = 1;
              Stop();
    Please create a new support case for your own. The original post is for SDK 10.0.0, NRF51822, and it was created 7 years ago.
    Amanda H.
