Hello. I am trying to port bootloader project from SDK to SES. But I do not know how to write data to UICR.
Steps what I've done:
- My nRF52832_xAA_MemoryMap.xml looks like (I've added UICR section):
< !DOCTYPE Board_Memory_Definition_File>
< root name="nRF52832_xxAA">
< MemorySegment name="FLASH" start="0x00000000" size="0x00080000" access="ReadOnly" />
< MemorySegment name="UICR" start="0x10001000" size="0x0000020C" access="ReadOnly" />
< MemorySegment name="RAM" start="0x20000000" size="0x00010000" access="Read/Write" />
< /root>
- To my flash_placement I've added:
< MemorySegment name="$(FLASH_NAME:UICR)">
< ProgramSection alignment="4" size="0x04" load="Yes" name=".uicrBootStartAddress" start="$(UICR_BOOTLOADER:0x10001014)" />
< ProgramSection alignment="4" size="0x04" load="Yes" name=".uicrMbrParamsPageAddress" start="$(UICR_MBR_PARAM_PAGE:0x10001018)" />
< /MemorySegment>
- At main file I've declared:
volatile uint32_t m_uicr_bootloader_start_address attribute ((section(".uicrBootStartAddress"))) = 0x55555555;
So for now I just want to write 0x55555555 in address UICR_BOOTLOADER:0x10001014
Project compiles without any errors/warning. At map file I have (this is obviously only part of map file):
0x10001014 0x4
0x10001014 __uicrBootStartAddress_start__ = .
*(.uicrBootStartAddress .uicrBootStartAddress.*)
0x10001018 . = ALIGN (MAX ((__uicrBootStartAddress_start__ + 0x4), .), 0x4)
*fill* 0x10001014 0x4
0x10001018 __uicrBootStartAddress_end__ = (__uicrBootStartAddress_start__ + SIZEOF (.uicrBootStartAddress))
0x00000004 __uicrBootStartAddress_size__ = SIZEOF (.uicrBootStartAddress)
0x10001018 __uicrBootStartAddress_load_end__ = __uicrBootStartAddress_end__
0x00000001 . = ASSERT (((__uicrBootStartAddress_start__ == __uicrBootStartAddress_end__) || ((__uicrBootStartAddress_end__ >= __UICR_segment_start__) && (__uicrBootStartAddress_end__ <= __UICR_segment_end__))), error: .uicrBootStartAddress is too large to fit in UICR memory segment)
0x10001018 __uicrMbrParamsPageAddress_load_start__ = 0x10001018
So it looks like, that .uicrBootStartAddress is in the right place.
After all this steps it should work, at least I've thought so. But when I erase my PCA10040 and download firmware to board, at address 0x10001014 I see only 0xFFFFFFFF:
C:\Program Files (x86)\Nordic Semiconductor\nrf5x\bin>nrfjprog.exe --memrd 0x10001014
0x10001014: FFFFFFFF |....|
(other firmware data is written to board without any problem - I see not 0xFFFFFFFF data from FLASH_START for bootloader (0x00072000)).
The question is: how to write data to UICR from Segger Embedded Stuido's project? Maybe I've done something wrong (forget something?) at the steps above?
