Is there a sample code for nRF52 SPI master without Soft device ?
I am trying to develop a simple SPI master for a custom nRF52832 uC, but I can't find anny sort of sample codes that don't use Soft devices for this task. I need the code to be simple, so no need for SD based codes. Is it possible or is the nordic SPI driver only usable through SD ?
  • The SPI driver code is independent of the softdevice. You can just take the code and use it without a softdevice and it will work fine. All the Nordic drivers are standalone and work with or without softdevices.
    If there are any places which use any sd_* functions at all, eg for configuring interrupts etc, there are a few files in the SDK with 'nosd' in their names which just provide trivial c implementations of those functions for simple source compatibility .. or you can just replace them with direct NVIC calls.
  • In SDK 11 there are two examples, SPIS and SPI, located in "SDK_11_folder\examples\peripheral". These examples show how to use SPI slave and master using the SPI(S) drivers without using the SD. It is as RK says though, it doesn't really matter if you use the SD or not other than that things might be a little clearer without thousands of lines of BLE stuff in the way.
  • I am unable to create a project from scratch with the spi drivers and the necessary files. I tried to create a new project and added the nrf_drv_spi driver and all the associated driver and config files to the project run-time environment, but I still got those errors for just compiling
    Rebuild target 'Target 1' compiling main.c... assembling arm_startup_nrf52.s... compiling system_nrf52.c... compiling nrf_drv_common.c... compiling nrf_delay.c... C:\Keil_v5\ARM\PACK\ARM\CMSIS\5.0.0-Beta4\CMSIS\Include\core_cm4.h(86): warning: #47-D: incompatible redefinition of macro "__WEAK" (declared at line 47 of "C:\Keil_v5\ARM\PACK\NordicSemiconductor\nRF_DeviceFamilyPack\8.6.1\Device\Include\compiler_abstraction.h") #define __WEAK attribute((weak)) C:\Keil_v5\ARM\PACK\NordicSemiconductor\nRF_Drivers\4.0.0-2.alpha\delay\nrf_delay.c: 1 warning, 0 errors compiling nrf_drv_spi.c... C:\Keil_v5\ARM\PACK\NordicSemiconductor\nRF_Drivers\4.0.0-2.alpha\spi_master\nrf_drv_spi.c(56): error: #35: #error directive: "Wrong configuration." #error "Wrong configuration." C:\Keil_v5\ARM\PACK\NordicSemiconductor\nRF_Drivers\4.0.0-2.alpha\spi_master\nrf_drv_spi.c: 0 warnings, 1 error compiling app_error.c... RTE\nRF_Libraries\nRF52832_xxAA\app_error.c(53): error: #29: expected an expression .line_num = line_num, RTE\nRF_Libraries\nRF52832_xxAA\app_error.c(54): error: #29: expected an expression .p_file_name = p_file_name, RTE\nRF_Libraries\nRF52832_xxAA\app_error.c(55): error: #29: expected an expression .err_code = error_code, RTE\nRF_Libraries\nRF52832_xxAA\app_error.c(67): error: #29: expected an expression .line_num = 0, RTE\nRF_Libraries\nRF52832_xxAA\app_error.c(68): error: #29: expected an expression .p_file_name = NULL, RTE\nRF_Libraries\nRF52832_xxAA\app_error.c(69): error: #29: expected an expression .err_code = error_code, RTE\nRF_Libraries\nRF52832_xxAA\app_error.c: 0 warnings, 6 errors compiling nrf_assert.c... ".\Objects\trial_3.axf" - 7 Error(s), 1 Warning(s). Target not created.
  • Hello Martrin,
    I tried to initialize and send packets using the SPIM0 peripheral using the nrf_spi & the nrf_spim0 environment config files and following the specification described in the product specification online, but with all my efforts I am unable to disable the other peripherals shared with the SPIM0 like the TWIM0, SPIS0 ... etc
    How can I disable the other shared peripherals ? I tried setting their enable to 0 but that didn't work
