I am using the nRF51822 bluetooth low energy smart beacon kit and am running into trouble using the GPIOs available on the board (pins 0, 1, 2, 3, 5, 9, 11, 20, 21, 24). For the purpose of this post, let's assume I only need to use one of them, i.e. pin 5.
How do I use the GPIO to output the 3 V coin cell battery voltage I am using to power the board? What needs to be set and to what values?
Do the high and low settings output the same voltage, but just allow for different levels of current?
I saw on another answered question that said it is not recommended to use the LDO to power any external circuitry. Is it even possible to access these regulated voltages (really I just want to use the 1.2 V from the LDO for part of an external circuit) from the GPIO? If so, why is it not recommended to use the LDO for powering an external circuit and what current draw to the external circuit might be acceptable?
Thank you in advance.
