Hi all,
BACKGROUND:
I'm working on a project where we use the nRF51, and our first prototype boards just arrived.
So I've made some power measurements trying to calculate the battery life:
When idle: 3,1uA
When bluetooth connected: 4,5mA
The bluetooth won't be connected that often, so this I can actually live with the resulting battery life for the prototype (gives me around 17-18 weeks battery life).
We're using a Panasonic CR1216 battery: industrial.panasonic.com/.../AAA4000C277.pdf
And just now I realised that the battery voltage takes a good drop when the bluetooth is connected for a longer time. The max connected time is 10sec and there I got:
Start: 2,99V drops exponentially to 2,7V over 10sec.
When the bluetooth disconnects it slowly climbs towards 2,99V again. I've waited 10min now and it is around 2,96V.
QUESTION:
In the battery datasheet I can't find anything about max discharge current? But clearly the 4,5mA is too much, and I found a similar battery (www.rossmannweb.de/.../CR1216_Renata_Rossmann.pdf ) where max discharge current is 1mA. So question is what will happen to the battery's 25mAh? (in general terms). And do you think it will be worth to look for an other battery that can handle higher discharge currents? - in that case any suggestions?
