ble_nus_c.c ...
I have problem with ble_nus_c.c in SDK v11...
Normal operation is:
Connecting to target 57E19A190FDF
Connected to target
[DB]: Starting discovery of service with UUID 0x1 for Connection handle 0
Found service UUID 0x1
[DB]: Discovery of service with UUID 0x1 completed with success for Connectionhandle 0
The device has the Nordic UART Service
But some times I have only this:
Connected to target
After some exploration, I found the problem: Sometimes ble_db_discovery_on_ble_evt(...) is in this
    on_disconnected(p_db_discovery, &(p_ble_evt->evt.gap_evt));
and specialy in this case in ble_nus_c_on_ble_evt(...)
p_ble_evt->evt.gap_evt.conn_handle == p_ble_nus_c->conn_handle
is not true, and this code is not launched
                ble_nus_c_evt_t nus_c_evt;
                nus_c_evt.evt_type = BLE_NUS_C_EVT_DISCONNECTED;
                p_ble_nus_c->conn_handle = BLE_CONN_HANDLE_INVALID;
                p_ble_nus_c->evt_handler(p_ble_nus_c, &nus_c_evt);
result: the BLE_NUS_C_EVT_DISCONNECTED is never fired and the scan_start() is never called !!!
My workaround:
        if (/*p_ble_evt->evt.gap_evt.conn_handle == p_ble_nus_c->conn_handle
                &&*/ p_ble_nus_c->evt_handler != NULL)
Please can you confirm ?
Regards, Gaétan
  • FormerMember
    0 FormerMember
    The reason that p_ble_evt->evt.gap_evt.conn_handle is not equal to p_ble_nus_c->conn_handle when the disconnect occurs, is that the disconnect occurs before the service discovery has finished, and p_ble_nus_c->conn_handle is set when the service discovery has finished. m_ble_nus_c/p_ble_nus_c->conn_handleis set in ble_nus_c_handles_assign(..). The result is that the corner case "disconnect before service discovery has finished" not will be handled correctly.
    The purpose of p_ble_evt->evt.gap_evt.conn_handle == p_ble_nus_c->conn_handle is to check that the disconnect was on the nus service connection (in case of connection to multiple devices with different services).
    Yes, if you want ble_nus_c_on_ble_evt --> BLE_GAP_EVT_DISCONNECTED to handle all disconnect events the same way (no filtering on connection handle), checking for event handler only (like you do) will be sufficient.
