Command-line GDB startup .gdbinit
Ole Morten has suggested using command-line GDB in a number of postings on this forum. Accordingly, I've tried to do that but always getting the following error ("Cannot find bounds of current function") on startup.
$ arm-none-eabi-gdb.exe tmp_gcc_s110_xxaa.out GNU gdb (GNU Tools for ARM Embedded Processors) 7.4.1.20130913-cvs Copyright (C) 2012 Free Software Foundation, Inc. This GDB was configured as "--host=i586-mingw32 --target=arm-none-eabi". For bug reporting instructions, please see: http://www.gnu.org/software/gdb/bugs/... 0x00012b98 in ?? () Flash download enabled Selecting device: nrf51822 Make breakpoint pending on future shared library load? (y or [n]) [answered N; input not from terminal] No symbol table is loaded. Use the "file" command. Target interface speed set to 1000 kHz Target endianess set to "little endian" Resets core & peripherals via SYSRESETREQ & VECTRESET bit. Reading symbols from C:\Nordic Semiconductor\nrf51_sdk_v5_1_0_36092\nrf51822\Board\nrf6310\s110\tmp\gcc_build/tmp_gcc_s110_xxaa.out...done. (gdb) l 1482 } 1483 1484 1485 /**@brief Function for application main entry. 1486 */ 1487 int main(void) 1488 { 1489 // Initialize. 1490 leds_init(); 1491 timers_init(); (gdb) n (gdb) Cannot find bounds of current function
My .gdbinit file contains the following:
target remote localhost:2331 monitor flash download = 1 monitor flash device = nrf51822 break main mon speed 1000 mon endian little mon reset 0
Does anyone know how to get command-line GDB to work? Does my .gdbinit contain the correct startup sequence? Thanks
