system off mode in nrf51822
hello there , i have put my nrf51 dk in system off mode.then i am generating interrupt using button 3 to wake up it. but my nrf51dk can't wake up. can you hel p me??
my main function and interrupt handler function are as below
    uint32_t err_code;
    bool erase_bonds;
	ret_code_t ret_code;
	    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
  ble_stack_init();
    gap_params_init();
    services_init();
    advertising_init();
	advertising_start();
    conn_params_init();
			  ret_code = nrf_drv_gpiote_init();
      nrf_drv_gpiote_out_config_t led_config = GPIOTE_CONFIG_OUT_TASK_LOW;
    ret_code =  nrf_drv_gpiote_out_init(LED_3, &led_config);
  err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
  nrf_drv_gpiote_in_config_t config =
      //  .sense = NRF_GPIOTE_POLARITY_HITOLO,
			.sense =NRF_GPIOTE_POLARITY_TOGGLE, //NRF_GPIOTE_POLARITY_LOTOHI,
       .pull = NRF_GPIO_PIN_PULLUP , // NRF_GPIO_PIN_NOPULL
			// .pull = NRF_GPIO_PIN_PULLUP ,
        .is_watcher = false,
        .hi_accuracy = false
        ret_code = nrf_drv_gpiote_in_init(INTERRUPT_PIN, &config, gpiote_evt_handler);
		nrf_drv_gpiote_in_event_enable(INTERRUPT_PIN,true);
		nrf_gpio_cfg_sense_input(INTERRUPT_PIN, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
			sd_power_system_off();
    while(true)
void gpiote_evt_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    switch(action)
      case    NRF_GPIOTE_POLARITY_TOGGLE:
            if(nrf_drv_gpiote_in_is_set(INTERRUPT_PIN))
            { // sd_power_system_off();
             // nrf_drv_gpiote_out_clear(LED_3);
							nrf_drv_gpiote_out_set(LED_3);
            //do nothing
    You need to configure a pin to be able to wake up from SYSTEM OFF, can be done like so:
    nrf_gpio_cfg_sense_input(WAKEUP_PIN, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
    sd_power_system_off():
    API documentation for nrf_gpio_cfg_sense_input here.
    Øyvind
  • This code is working fine for me on the nRF52 DK, I just added two line to the ble_app_beacon example
        uint32_t err_code;
        // Initialize.
        err_code = bsp_init(BSP_INIT_LED, APP_TIMER_TICKS(100, APP_TIMER_PRESCALER), NULL);
        ble_stack_init();
        advertising_init();
        // Start execution.
        nrf_gpio_cfg_sense_input(13, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_HIGH); // Added this
        sd_power_system_off();        // Added this
        // Enter main loop.
        for (;; )
            power_manage();
    Make sure that you set the PULLUP/PULLDOWN and sensitivity correctly (active low or high depending on your configuration).
        uint32_t err_code;
        // Initialize.
        ble_stack_init();
        advertising_init();
        // Start execution.
        // Enter main loop.
        for (;; )
            power_manage();
