HFCLKSTATE do not update to 0x10001
Hi, Everyone,
I am Using S130 and sdk 11.0.0.2-alpha with nRF51422 chip. I have two crystal in my custom pcb, one is 32 Khz crystal for LFCLK between XL1 and XL2 (pin 45,46 ) and other is 16Mhz HFCLK between XC1 and XC2(pin 37, 38)
Inside ble_stack_init()
I use either following only for 32Khz external osciilator initialization SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_250_PPM, NULL);
OR following only when using internal RC osc SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_RC_250_PPM_TEMP_16000MS_CALIBRATION, NULL);
when I switch LFCLK to internal RC then HFCLK gets updated to 0x10001 -which is external 16Mhz crystal. All perfect , no problem
But when I use 32 Khz external crystal as LFCLK, HFCLK stays to 0x10000 - which says internal RC instead of external oscillator
According to the specs, Radio should not work without external crystal HF clock source, But I can see Advertised data in Master control panel, with accurate information even when i use external 32 khz crystal for LFCLK and HFLCK stays to 0x10000
Can anybody make me clear here ???
  • This is exactly the same question you asked yesterday and I answered yesterday, don't repost questions ad nauseum just because you don't understand the first answer.
    And I told you the same thing, when you change the LF clock source there's no point looking at the HF clock source register, look at the LF clock source register.
    The HF clock source, as I also told you yesterday, is started and stopped as necessary by the softdevice when it needs to use the radio or do other things it needs the crystal source for, like for instance, calibrate the LF clock source.
    So HFCLOCK does not stay using the RC source, it will be turned on and off as required, and the state it's in just after you change the LF clock source is completely irrelevant.
  • I guess answer from stefan above explains the reason in better manner !!!
