Hi I am working on activity detection using ADXL362 and nrf52. When I am moving the accelerometer ideally I should get activity interrupt in status register and when ADXL362 is stationary it should generate inactivity interrupt and it is updated in status register.When I am moving ADXL362 i am getting 0x40 or 0x41 in status register(not at all the time). please suggest me why I am not getting inactivity interrupt when it is stationary.Following is my code: Hoping for positive response!!
#include "nrf_delay.h"
#include "app_error.h"
#include "nrf_drv_spi.h"
#include "bsp.h"
#include "app_timer.h"
#include "nordic_common.h"
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "app_uart.h"
#include "nrf.h"
#include "nrf_temp.h"
#include "boards.h"
#include "nrf_drv_gpiote.h"
#define APP_TIMER_PRESCALER 0 ///< Value of the RTC1 PRESCALER register.
#define APP_TIMER_MAX_TIMERS BSP_APP_TIMERS_NUMBER ///< Maximum number of simultaneously created timers.
#define APP_TIMER_OP_QUEUE_SIZE 5 ///< Size of timer operation queues.
#define DELAY_MS 1 ///< Timer Delay in milli-seconds.
#define TX_RX_MSG_LENGTH 100
static uint8_t m_tx_data_spi[TX_RX_MSG_LENGTH]; ///< SPI master TX buffer.
static uint8_t m_rx_data_spi[TX_RX_MSG_LENGTH]; ///< SPI master RX buffer.
void read(nrf_drv_spi_t const * p_instance, uint8_t reg, uint8_t rx_data_spi[6]);
uint8_t read_one_byte(nrf_drv_spi_t const * p_instance, uint8_t reg);
void write(nrf_drv_spi_t const * p_instance, uint8_t reg, uint8_t value);
void write_one_byte(nrf_drv_spi_t const * p_instance, uint8_t reg, uint8_t value);
void temperature(void);
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action);
//=================================================GPIO and Interrupt routine===========================
#ifdef test_pin
#define PIN_IN test_pin
#ifndef PIN_IN
#error "Please indicate input pin"
#ifdef BSP_LED_0
#define PIN_OUT BSP_LED_0
#ifndef PIN_OUT
#error "Please indicate output pin"
static void gpio_init(void)
ret_code_t err_code;
nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
err_code = nrf_drv_gpiote_out_init(PIN_OUT, &out_config);
nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
in_config.pull = NRF_GPIO_PIN_PULLUP;
err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_config, in_pin_handler);
nrf_drv_gpiote_in_event_enable(PIN_IN, true);
/** @def TX_RX_MSG_LENGTH
* number of bytes to transmit and receive. This amount of bytes will also be tested to see that
* the received bytes from slave are the same as the transmitted bytes from the master */
#define MAX_TEST_DATA_BYTES (15U) /**< max number of test bytes to be used for tx and rx. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 1 /**< UART RX buffer size. */
void uart_error_handle(app_uart_evt_t * p_event)
if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
else if (p_event->evt_type == APP_UART_FIFO_ERROR)
#ifdef ENABLE_LOOPBACK_TEST
static void uart_loopback_test()
uint8_t * tx_data = (uint8_t *)("\n\rLOOPBACK_TEST\n\r");
uint8_t rx_data;
// Start sending one byte and see if you get the same
for (uint32_t i = 0; i < MAX_TEST_DATA_BYTES; i++)
uint32_t err_code;
while(app_uart_put(tx_data[i]) != NRF_SUCCESS);
nrf_delay_ms(10);
err_code = app_uart_get(&rx_data);
if ((rx_data != tx_data[i]) || (err_code != NRF_SUCCESS))
show_error();
return;
#if (SPI0_ENABLED == 1)
typedef enum
TEST_STATE_SPI0_LSB, ///< Test SPI0, bits order LSB
TEST_STATE_SPI0_MSB, ///< Test SPI0, bits order MSB
END_OF_TEST_SEQUENCE
} spi_master_ex_state_t;
static volatile bool m_transfer_completed = true;
static spi_master_ex_state_t m_spi_master_ex_state = (spi_master_ex_state_t)1;
static const nrf_drv_spi_t m_spi_master_0 = NRF_DRV_SPI_INSTANCE(0);
void app_error_handler(uint32_t error_code, uint32_t line_num, const uint8_t * p_file_name)
UNUSED_VARIABLE(bsp_indication_set(BSP_INDICATE_FATAL_ERROR));
/*for (;;)
// No implementation needed.
uint8_t tempvar1;
nrf_drv_spi_t const * p_instance;
p_instance = &m_spi_master_0;
printf("Done!!!\r\n");
nrf_drv_gpiote_out_clear(PIN_OUT);
nrf_delay_ms(20);
tempvar1=read_one_byte(p_instance,0x0B);
//while(((tempvar1) & 0x20)==0x00);
printf("Status_Register_ISR= %x\r\n",tempvar1);
/**@brief Handler for SPI0 master events.
* @param[in] event SPI master event.
void spi_master_0_event_handler(nrf_drv_spi_event_t event)
switch (event)
case NRF_DRV_SPI_EVENT_DONE:
// Check if received data is correct.
//result = check_buf_equal(m_tx_data_spi, m_rx_data_spi, TX_RX_MSG_LENGTH);
//APP_ERROR_CHECK_BOOL(result);
//nrf_drv_spi_uninit(&m_spi_master_0);
//err_code = bsp_indication_set(BSP_INDICATE_RCV_OK);
//APP_ERROR_CHECK(err_code);
#endif // (SPI0_ENABLED == 1)
/**@brief Function for initializing a SPI master driver.
* @param[in] p_instance Pointer to SPI master driver instance.
* @param[in] lsb Bits order LSB if true, MSB if false.
static void spi_master_init(nrf_drv_spi_t const * p_instance, bool lsb)
uint32_t err_code = NRF_SUCCESS;
nrf_drv_spi_config_t config =
.ss_pin = SPIM0_SS_PIN,
.irq_priority = APP_IRQ_PRIORITY_LOW,
.orc = 0x00,
.frequency = NRF_DRV_SPI_FREQ_2M,
.mode = NRF_DRV_SPI_MODE_0,
.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST,
//.bit_order = (lsb ?
// NRF_DRV_SPI_BIT_ORDER_LSB_FIRST : NRF_DRV_SPI_BIT_ORDER_MSB_FIRST),
if (p_instance == &m_spi_master_0)
config.sck_pin = SPIM0_SCK_PIN;
config.mosi_pin = SPIM0_MOSI_PIN;
config.miso_pin = SPIM0_MISO_PIN;
err_code = nrf_drv_spi_init(p_instance, &config,
spi_master_0_event_handler);
void act_inact_init()
write(p_instance,0x20,0x5C); //activity threshold_L dec 250=0xFA
while(m_transfer_completed == false)
m_transfer_completed = false;
write(p_instance,0x21,0x00); //activity threshold_H=0x00
write(p_instance,0x23,0x50); //inactivity threshold_L dec 150=0x96
write(p_instance,0x24,0x00); //inactivity threshold_H dec 0=0x00
/*write(p_instance,0x22,0x01); //activity timer dec 30=0x1E here ODR = 100 Hence Time in sec = 30/100 = 0.3 sec
m_transfer_completed = false;*/
write(p_instance,0x25,0x01); //inactivity timer dec 30=0x1E here ODR = 100 Hence Time in sec = 30/100 = 0.3 sec
write(p_instance,0x27,0x3F); //loop mode,referenced mode.
write(p_instance,0x2B,0x70); //awake,Activity,Inactivity interrupts and Active low INT2 pin
write(p_instance,0x2C,0x83);
write(p_instance,0x2D,0x0A); //begin measurement
/**@brief Function for executing and switching state.
static void switch_state(void)
switch (m_spi_master_ex_state)
case TEST_STATE_SPI0_LSB:
spi_master_init(p_instance, true);
case TEST_STATE_SPI0_MSB:
spi_master_init(p_instance, false);
return;
// adxl_int();
/**@brief Function for initializing bsp module.
void bsp_configuration()
NRF_CLOCK->LFCLKSRC = (CLOCK_LFCLKSRC_SRC_RC << CLOCK_LFCLKSRC_SRC_Pos);
NRF_CLOCK->TASKS_LFCLKSTART = 1;
while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0)
// Do nothing.
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, NULL);
err_code = bsp_init(BSP_INIT_LED, APP_TIMER_TICKS(100, APP_TIMER_PRESCALER), NULL);
/** @brief Function for main application entry.
// Setup bsp module.
bsp_configuration();
gpio_init();
LEDS_CONFIGURE(LEDS_MASK);
LEDS_OFF(LEDS_MASK);
switch_state();
act_inact_init();
//nrf_temp_init();
uint8_t tempvar[8] = {0},tempvar1;
short temp1;
uint32_t err_code;
int32_t volatile temp;
const app_uart_comm_params_t comm_params =
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
APP_UART_FLOW_CONTROL_ENABLED,
false,
UART_BAUDRATE_BAUDRATE_Baud115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_error_handle,
err_code);
if (m_transfer_completed)
m_transfer_completed = false; //it equivalent to TI flag in 8051 checking TI==0;
while(true)
act_inact_init();
write_one_byte(p_instance,0x0B,0x00);
while(m_transfer_completed == false);
nrf_drv_gpiote_out_set(PIN_OUT);
//printf("Interrupt not generated\r\n");
nrf_delay_ms(100*DELAY_MS);
read(p_instance,0x0E, tempvar);
printf("Status Register = %x\r\n",tempvar1);
/* if((tempvar[3] & 0x08) == 0x08)
temp1=(short)((tempvar[3] & 0x07)<<8 | tempvar[2] | 0xf800);
printf("%d\t", temp1);
temp1=(short)((tempvar[3] & 0x07)<<8 | tempvar[2] | 0x0000);
printf(" %d\t", temp1);
if((tempvar[5] & 0x08) == 0x08)
temp1=((tempvar[5] & 0x07)<<8 | tempvar[4] | 0xf800);
temp1=(short)((tempvar[5] & 0x07)<<8 | tempvar[4] | 0x0000);
if((tempvar[7] & 0x08)== 0x08)
temp1=((tempvar[7] & 0x07)<<8 | tempvar[6] | 0xf800);
printf("%d\n\r", temp1);
temp1=(short)((tempvar[7] & 0x07)<<8 | tempvar[6] | 0x0000);
//printf("%d\t%d\t%d\n\r", tempvar[2], tempvar[4], tempvar[6]);
//printf("%d\t%d\t%d\t%d\t%d\t%d\t\n\r", tempvar[2], tempvar[3], tempvar[4],tempvar[5],tempvar[6],tempvar[7]);
m_tx_data_spi[0] = 0x0B;
m_tx_data_spi[1] = reg;
m_tx_data_spi[2] = 0x00;
uint32_t err_code = nrf_drv_spi_transfer(p_instance,
m_tx_data_spi, 2, m_rx_data_spi, 3);
return m_rx_data_spi[2];
m_tx_data_spi[0] = 0x0A;
m_tx_data_spi[2] = value;
m_tx_data_spi[3] = 0x00;
uint32_t err_code = nrf_drv_spi_transfer(p_instance,m_tx_data_spi, 3, m_rx_data_spi, 3); //istead of 3 length of m_rx_data_spi 0 was written?
